Audi Coupe Quattro 7a --> 1z TDi swap questions
  • De80q
    • Nov 2016
    • 56
    Are you calculating that with the CQ 01A, or the sedan 01A? The sedan has a slightly taller 5th gear than the CQ.
    • etsola
      • Feb 2015
      • 285
      Well, it'd be the 5th from a DGW 01A from a 1996-1998 A4 TDI Quattro... Which 5th is 0.66... Very tall.
      There's O1E 6 gears that the 6th is 0.56!
      I'll calculate with stock 01A... But thanks I had notice it was taller on the Sedan but didn't think of making the calculations I think it'll Rev too high.
      Do you know if I can swap the rear diff ring and pinion from a B4 into our B3 casing? There 3.89 instead of 4.11.
      • M2ki
        • Aug 2015
        • 547
        No, you can't.
        1989 Audi 80 Quattro
        • De80q
          • Nov 2016
          • 56
          It has been tried, and can't be done. If you can find a UrQ rear diff, that will give you the final gearing you are looking for. I know a couple people who have put them into B3's.
          From what I have found, the B3 sedan has a .769 5th gear, and the CQ has a .838 5th gear. I'll be dropping in a sedan 01A into the CQ I'll be picking up soon.
          • etsola
            • Feb 2015
            • 285
            I found out that the 5th of the 01A DGW or EEP is 0.659
            That probably be enough to make decent rpm on the highway with 4.11.
            Is changing the 5th gear impossible too?!
            Other question is how to find : 012 311 361 CF
            • etsola
              • Feb 2015
              • 285
              Also, does that 01A bolt to a 4cyl or not? I've heard the drilling was meant for both since found in both applications...?
              • M2ki
                • Aug 2015
                • 547
                Ofcourse it does. 4 cyl came with 01A gearbox from factory.
                You'll also need the matching input shaft and matching gear for that shaft.
                • De80q
                  • Nov 2016
                  • 56
                  You may find this thread of use.
                  • Bowie69
                    • Nov 2013
                    • 2681
                    I'm gonna say what everyone else is thinking -this is just sacrilege!
                    • PRY4SNO
                      • 767
                      Why not use a more common 5-cylinder TDI, either an AEL or AAT? Just feels more proper in a Cq. Plus they actually have some jam, and will still return excellent mileage. I think Martin was getting 1000 km or better per tank in his sedan.
                      2013 Touareg TDI /// #farmenwagen
                      • etsola
                        • Feb 2015
                        • 285
                        So you mean the input shaft is not the same diameter as the ones in 7a's?
                        Thanks for the input guys... I'll look into that when I'm in front of a computer
                        • etsola
                          • Feb 2015
                          • 285
                          Ok, let's say I'd want to go the "easy" route and put a 1z engine (easily available here) and bolt it to a sedan 01A transmission (longer 5th).
                          What would I need from a longitudinal 1z (never had them mounted longitudinally here in America) ?
                          -Oil pan ?
                          -Engine Mounts ? --> would they fit the 7a quattro subframe ?
                          -I guess I'll need 7a clutch and flywheel to match the output shaft ?
                          Any help on what may be needed would help I'm going to Europe in september and may like to source the parts while I'm there
                          • M2ki
                            • Aug 2015
                            • 547
                            You'll need a longitudal 1Z block. Left and front mounts are different on the block.
                            • sam80quattro
                              • Oct 2006
                              • 1496
                              b4 80 1z flywheel and clutch. Pd130 out of a b6 is surely a better shout?
                              • etsola
                                • Feb 2015
                                • 285
                                Really?!? The block is different?! Never would've thought... That makes it more complex...
