Can you disable factory alarm?
  • gunman
    • Jan 2009
    • 660
    Got woke up at 6.30 this morning with the sound of the alarm going off on the 80 tdi, not very welcome thing to happen on a Sunday morning (Dont think the neighbours were too happy either). I pulled the battery lead on it so I could get back to sleep (which dodn't happen BTW).
    Central locking not working either now, which I beleive is all connected. I had lent my Vagcom to a workmate for his S6, so it's sitting on my desk at work. I'll bring it home tomorrow to try to fix it (great excuse to use the S2 tomorrow )
    I've searched on here and other forums and cant find if there is a way to disable the factory alarm using vagcom. Has anyone done this before?
    Cheers.
    1996 Audi S6 Avant.
    1994 80 TDI - Daily Driver
    Central locking and standard audi alarm are on the same fuse.
    The standard alram can only be armed if you you are locking and unlocking the car via the key in the drivers door.
    If you have an aftermarket alarm then just use that fob or fit a cheap locking kit that uses a fob
    • gunman
      • Jan 2009
      • 660
      Thanks, I've pulled the fuse now until such times as I can get vagcom and more time to look at it.
      1996 Audi S6 Avant.
      • mdz
        • Jun 2012
        • 775
        • Country: Latvia
        80's factory alarm does not talk to vagcom.
        • madpugger
          • Sep 2007
          • 1901
          Mine only Arms/Disarms when locking from the Pass side or Tailgate, Driver side no worky....
          Le Mans 2012
          Nurburgring 700
          1995 S2 Avant
          • Joop
            • May 2015
            • 89
            i have exactly the same problem off the battery and
            after no alarm and ir remote.
            Did you solve the problem?
            • HuwSy
              • Apr 2011
              • 181
              Hi. Very old thread but since the battery was pulled to change a starter motor every time I open a door now the factory fit alarm goes off and I have no central locking. Is there some way to disable the factory fit alarm or resetup the keys which have been without batteries for years. Thanks
              • HuwSy
                • Apr 2011
                • 181
                Ah I think I have found the issue. The central locking pump failed. Anyone have a spare pump?
