Feeler for GB, Supertech valves
  • terrybullwon
    • Mar 2006
    • 8782
    Guys i know this will not appeal to every one but i have been incontact with a company that can supply these valves at already a very good price and they may well flex alittle more if i can get a few more sets on the order
    Please have a look around the web Site
    And here's the pdf file, page 10
    Supertech Performance offers high quality racing components, valves, pistons, spring and valve train engine components for the automotive industry. We are the leading manufacturer for high performance valves, pistons, springs and valve train engine components.
    Chef
  • terrybullwon
    • Mar 2006
    • 8782
    Doubt this will take off, i have a email stating that 10 buyers are needed to get a even better price
    Cheers James
    Chef
    • s2_bo
      • Oct 2005
      • 6067
      They even make Valves out of chrome nitride! - What the hell is that then?
      91 S2 coupé - RIP
      98 S8 - Luxury barge
      • terrybullwon
        • Mar 2006
        • 8782
        Tis just a coating Bo, think it wears well
        Chef
        • HPmuirt
          S2Forum April Fool
          • Apr 2005
          • 3014
          Which valves are you thinking of going for (and why)? Are you looking for lightweight for high revving or long lasting etc?
          Also, what is the price range for a set and the saving if we get 10 folks?
          Cheers n
          Si
          Subtle mods here and there
          2011 A5 3.0 TDi - Lava Grey
          • terrybullwon
            • Mar 2006
            • 8782
            Cheers n
            Si
            Si,
            VWIVN-1034 - Intake £8.60
            VWEVN-1034 - Exhaust £8.50
            These prices are before a GB price.
            The valves i will be using will be of standard size.
            The long life span is a great pull and they weigh a bit less.
            The Nitrided valves will have a surface hardness almost 2-3 times stronger than cromed.
            Chef
            • s2_bo
              • Oct 2005
              • 6067
              Originally posted by terrybullwon
              Si,
              Also need is valve guides as they use a stem dia of 7mm to the oem of 8mm (price tbc)
              Thats cheaper than i thought they would be.
              Has any one on here used them before?
              91 S2 coupé - RIP
              • terrybullwon
                • Mar 2006
                • 8782
                Originally posted by EspenW
                One option is to stick to the stock size, but use valves with thinner stems, thus increasing flow. I've got the Supertech http://www.supertechperformance.com on the Golf. Stock thickness of the stems are 8mm, but these are 7mm (requiring new guides). Undercut to 6.5mm in the area that does not touch the valve guide. Much lighter than stock too. Saves a lot more weight than TI retainers. In combination with lightweight lifters, this setup is good for 8K on the 8v Golf, thus avoiding stiffer valve springs (stiffer springs sap power at all rpms).
                Also used by Albert
                Chef
                • terrybullwon
                  • Mar 2006
                  • 8782
                  I have received another email back from supertech.
                  Valve seals per set £7.52 per 20
                  Valve stems from another source £35.90 per 24
                  Chef
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    Total price for valves £171
                    New valve seals £7.52
                    Shipping £23
                    Guys remember oem valves cost alot more
                    Chef
                    • HPmuirt
                      S2Forum April Fool
                      • Apr 2005
                      • 3014
                      Si,
                      Seems like a good price. Which core material are you going for? Is it worth going for titanium?
                      Cheers n
                      Si
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        Cheers n
                        Si
                        As far as i can see, the valves are made for a hi quality alloy and chrome nitride coated.
                        You can go Ti to reduce the valve train weight and increase the spring life, but titanium valves wear or gall on the valve seats.
                        I have Ti retainers and springs though
                        Chef
                        • Flat on my back
                          • Jan 2007
                          • 2449
                          Thought you was trying to keep the costs down, just cos its shiny and new doesn't mean you have to buy it, though it helps.
                          Could be interested myself.
                          Carlos.
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            Its far to late to worry about cost now
                            And if your going to do it, you may as well do it right
                            Chef
                            • LHD_Kid
                              • May 2006
                              • 3695
                              Yes, I have always lived by the rule...
                              If you're gonna get caught with your hand in the pickle jar, make sure you're right up to the elbow........
                              Chris
