Coupe Rear Tie Rod bushes
  • Flat on my back
    • Jan 2007
    • 2449
    Alex.
    These peeps were near you...till you moved...
    Might be worth a call on the poly front.
    We are the leading UK polyurethane manufacturers in Birmingham, United Kingdom. We work with the best manufacturers in the polyurethane industry.
    For info.
    Carlos.
    • s2driveruk
      • 12696
      price dependent i'd be up for a set too.
      David
      1992 3b S2 Coupe
      • Flat on my back
        • Jan 2007
        • 2449
        And more info...
        This...
        Carlos.
          Cheers Carlos
          I've been so busy with work since I got back from Canada I haven't chased up the manufacturers I spoke to originally - so to answer the question - no progress!
          I'll get on the case with this.
          Did anyone manage to find out of the Type 85 rods were the same size bush?
          • Graham
            • 1622
            #35
            I'm up for a set also count me in
              Error 404
              Madwolf_uk
              Acidburn
              Andy_casey?
              S2central
              Spink?
              Anton
              Goodall
              Terrybullwon
              k.alle
              mikeraz1
              s2driveruk
              Graham
              Currently looking at machined bushes in Nylon66 - awaiting ballpark costs so watch this space
                Count me in too, price pending
                • Kieron20V
                  • Mar 2008
                  • 1505
                  #38
                  Ill go for a pair, why not.
                  Kieron.
                  1994 URS4 Avant RS2+
                    Error 404
                    Madwolf_uk
                    Acidburn
                    Andy_casey?
                    S2central
                    Spink?
                    Anton
                    Goodall
                    Terrybullwon
                    k.alle
                    mikeraz1
                    s2driveruk
                    Graham
                    Greg_S
                    Kieron20v
                    They will likely be Poly of 90-95A hardness, so similar to the Powerflex wishbone bushes.
                    Still waiting on details from several manufactuers, but price is likely to be somewhere in the region of £30 a set delivered (in UK) based on 20 sets.
                    • Acidburn
                      • 13459
                      Cool mate, defo up for a set then
                      • Pirvu Eugen
                        • Apr 2007
                        • 1978
                        • Country: Romania
                        #41
                        I will love a set also! Count me in please!
                        Will be interesting iff is posiible to build for the front arms also not for the rear only!
                        All the best!
                        Eugen
                          Will be looking at bushes for the front tie rods too hopefully
                          • Jas11n
                            • 5067
                            Me too;
                            Madwolf_uk
                            Acidburn
                            Andy_casey?
                            S2central
                            Spink?
                            Anton
                            Goodall
                            Terrybullwon
                            k.alle
                            mikeraz1
                            s2driveruk
                            Graham
                            Greg_S
                            Kieron20v
                            Pirvu Eugen
                            Jas11n
                            2001 Avus Silver B5 RS4.
                            1995 S2 Coupe - sold (sniff)
                              Ok, i'm looking at using a polyurethane manufacturer and a separate machinist for the sleeves as none of the bush specialists were interested.
                              So, the bushes would be cast out of 90-95A hardness PU, inner bores knurled to lower contact area with sleeve and retain lubricant.
                              Sleeves would be manufactured from T316 Stainless Steel.
                              I'd appreciate it if any of you engineer types could cast a critical eye over my design (attached) and comment on suitability. My idea is that the bush is an interferance fit into the rod end, and the sleeve is a tight fit in the bush, but allowing the bush to rotate around the sleeve.
                              I haven't yet taken accurate measurements of the rod end, bush or sleeves so all dimensions are approximate at this stage. once I've done that everything is pretty much ready, pending financing which bring me to my next point:
                              Manufacturing 20 sets would cost £580 + P&P which I can't front at the moment unfortunately - so would need payment upfront from people, then with a lead time of 3-4 weeks to delivery.
                              what do poeple think?
                              • Flat on my back
                                • Jan 2007
                                • 2449
                                Dont bother with the 316 ss, 304 will do the job plenty and be cheaper and easier to work.
                                Good luck.
                                Can you switch the chamfer for a simpler radius?
                                Carlos.
