Front Tie rod innner end bushes
  • bambridge
    • May 2009
    • 609
    Originally posted by powercar
    hi kev, you still have this adjusters and bushings for sale?
    Yes still have them in stock.
    I will pm you all details
    Kev
    • powercar
      • May 2008
      • 93
      • Country: Norway
      #62
      yes that would be nice
      IG: Alb garage
      • Big Lee M
        • 2571
        Hi Kev, have you got any of the adjusters left? As I've just looked at the little stupid 14mm hex nut on it and thought was a waste of space? Plus I've replaced one tie rod and doing the other side as that is knackered too, well the tracking guy said it would be best(for him maybe??) if I replaced both. Let me know ASAP.
        Lee
        Just some finishing touches to do now
        • my2000apb
          • Jul 2010
          • 637
          ygPM
          BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
          DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
          • Mcstiff
            • Oct 2004
            • 504
            Any thoughts on these causing bracket flex because of too much resistance to torsional (fore and aft) flex? I'm thinking of the tie rod angle change as the steering cycles through it's range. If this is not a concern, I'd love some!
            1995 1PissedOff90sigpic1991 USDM CQ 7aT
            • my2000apb
              • Jul 2010
              • 637
              id convert to a heim inner setup as I also believe they need more than one plane of movement
              • Mcstiff
                • Oct 2004
                • 504
                That is probably my end game but this would be a quicker implementation.
                • my2000apb
                  • Jul 2010
                  • 637
                  drill out your oem upright for a 1/2" bolt and use misalignment spacers inner and outer to make steering rods, easy ****
                  just make sure to use a larger washer to captivate the rod end on the nonsteering arm side in the event of a rod end failure
                  • Mcstiff
                    • Oct 2004
                    • 504
                    Yeah, wanting to keep OEM style TREs is really the hard part. I need some outer adjusters that convert from metric to standard so I can run off the shelf tie rods.
                    • my2000apb
                      • Jul 2010
                      • 637
                      why do you want oem ends?
                      • caterpillar
                        • 2480
                        #71
                        i use some antizeise on these parts.. some wood tare / ev copperslip; will have the free from rust, and easy to adjust laiter....
                        • frostyflax17
                          • Mar 2010
                          • 248
                          just ordered a set.
                          isn't there a tie rod end that has a "nut" around the base so that they can be held in place as well while maneuvering? all these febi/monroe/feq ones are all just round.
                          so this guy
                          vs say this guy
                          exactly what i'm looking for... but will fit the coupe quattro
                          2011 black VW Touareg TDI - Daily/hauler
                          1991 black CQ- rally poser
                          1990 titan CQ- rombotis brunhilde racecor
                          1986 black Yamaha Fazer FZX - cafe bike project
                            I know on mine they are the tapered end with a washer luck nut that tightens against it. Dont think there will be anything wrong with the others as you will have lock nuts that tighten against it anyway
                            • my2000apb
                              • Jul 2010
                              • 637
                              you don't need a wrench flat on the tie rod end
                              it will be tight in the steering arm, and you hold the center barrel adjuster and tighten the lock/jam nut against that, the TRE just sits there
                              • sidrick
                                • Jan 2011
                                • 1342
                                Is there anyone else that can supply replacements/upgrades if I can't get hold of Bambridge?
