Following the development of the 302mm and 314mm rear brake upgrade using stock calipers and pads with larger discs and adaptors, I am looking to get a batch of parts made up.
I've done my sums based on a batch of 5 of each kit and due to how close the brackets are in price, the cost will be £120 delivered in the UK for a kit comprising of:-
To complete the kit, you will need to buy:-
302mm x 11mm thick rear discs from a Mazda 5:-
or
314mm x 11mm rear discs from a Mazda 6 MPS:-
New brake pads, if required:-
Cheapest discs & pads are about £60 delivered for the lot!
302mm 'basic' setup:-
314mm Rusty setup vs. stock:-
314mm under ABY Avus:-
Both setups fit under 16" ABY Avus without spacers and require no modification to handbrake lines or removal of hydraulic parts.
The 302mm option uses a current production disc, whereas the 314mm uses a rarer disc from a 5 year old car. In that respect, it's up to you which setup you go for...
Please register your interest below:
- 2 x Brackets - Zinc coated mild steel (chosen over the cheaper alloy option)
- 2 x Spigots - Zinc coated mild steel
- 8 x M12 20mm high tensile fine pitch bolts
- 1 x 17mm HSS drill bit
- Brembo - 08.A711.10
- Apec - DSK2752
- National - BD1600 (for grooved & black coated PBD1600GB)
- Pagid - 54482
or
- Apec - DSK2723
- National - PBD1564GB (for grooved & black coated PBD1564GB)
- Mintex - MDC2027
- EBC Yellows - DP4370R
- DS2500 - FCP596H_25
All go ok with the v.2 mods?
