Hi there guys just received my ARP headbolts just a quick query there seems to be a issue with the washer that are supplied with the head studs from what i read on he search area.
can you guys plse confirm one way or the other if it is wise to use the sportquattro washers p/n 035 103 377 with these head studs, or are the standard washers fine
because i few of you guys are using these bolts so if anyone knows you guys will
Cheers Raj ABY
Cheers Raj ABY
The only issue I can see, would be if you used ARP or similar bolts with the OE torque values.
