Arp
  • baltiboyS2
    • 965
    Arp
    Hi there guys just received my ARP headbolts just a quick query there seems to be a issue with the washer that are supplied with the head studs from what i read on he search area.
    can you guys plse confirm one way or the other if it is wise to use the sportquattro washers p/n 035 103 377 with these head studs, or are the standard washers fine
    because i few of you guys are using these bolts so if anyone knows you guys will
    Cheers Raj ABY
    Doug_RS2 uses the sportquattro washers, good enough for me if good enough for MRC.
    • baltiboyS2
      • 965
      That sounds good to me i have tryed to order the sportquattro washers but audi are out of stock of them
      RAJ ABY
        • baltiboyS2
          • 965
          I already found the old post on the search function JAMO
          but the problem i have is were can i get a hold of these washers
          Raj ABY
          • SteveH
            • 4460
            I've been using mine with the ARP washers for 1 1/2 years with no issues. Head has been off since they were fitted and there was nothing to suggest they cause problems. From memory the Sport quattro washers have a slightly larger diameter, however nobody has problems with the standard washers on the OE S2 headbolts, and they are approximately the same size as the ARP washers The only issue I can see, would be if you used ARP or similar bolts with the OE torque values.
            I like Tom's quote in his post....."I opted not to use them in the end. I guess i was working on the assumption that i never want to pull the engine apart again"
            Steve
            91 Modded 3B
            14 A6 Avant Black Edition
            • Mark Halligan
              • 2001
              I use them with the supplied ARP washers too, I've had the the head on and off about three or four times since installing them (yep really!) and each time I have checked the head for damage around the washer seating area....none.
              These studs have paid for themselves easily by now, great, useful piece of kit.
              Originally posted by SteveH
              I like Tom's quote in his post....."I opted not to use them in the end. I guess i was working on the assumption that i never want to pull the engine apart again" Steve
              I used to think like that too LOL
              Mark - Modded
              • AnLe
                • Dec 2003
                • 291
                well, my arp dig into to my head, changed to spq items, and no more digging.
                std washers are bigger than arps, cheap solution is use washers from your old std bolts.
                • baltiboyS2
                  • 965
                  Thanks for all your info guys i think i will try and get the sport quattro washer if i cant then i will have to use what i have
                  Oh by the way what torque setting did you use to bolt the head down
                  Raj ABY
                  • Corey
                    Banned
                    • Sep 2003
                    • 2793
                    65ft lbs to torque them down follow the factory sequence. Warm the engine up then retorque them again to 65ft lbs, do not undo them just retighten. This figure is only applicable if you use the ARP moly slip.
                    Corey
                    01636 822288
                    • Mark Halligan
                      • 2001
                      Just been trawling through old threads and forgot I posted this.
                      Time for me to do a big U turn, the last time I had the head off again (not long after that post), I found that the ARP washers had sunk into the head on almost every stud, in fact a few of the bolt holes on the exhaust side had actually closed up a little where the ally of the head had been displaced slightly.
                      I dont know why they did it that time as they have always been torqued as per the ARP specs.
                      Its a good head with a lot of work put into it so I had to have the area that the washers sit on re-machined flat and got some SQ washers from VAGparts, hopefully all is OK now.
                      Still think that the ARP studs are great but I'll make sure I'll continue to use them with the bigger washers in future.
                      Mark - Modded
                      • SteveH
                        • 4460
                        Interesting Mark, the head is coming off when I do the engine and gearbox. I'll take a good look at the head to see if the same has happened to mine. I wonder if this issue has been reported to ARP?
                        91 Modded 3B
                        • auditude
                          • 407
                          I just sent them a note and referred to this thread.
                          Kenneth
                          1990 Coupe quattro
                          1991 200q20v x 2
                          1985 4ksq 20vt project
                          1986 Coupe GT 10vt project
                          2006 Honda Ridgeline
                          1998 Honda VFR800FI
                          • 1975DCS
                            • Sep 2006
                            • 258
                            Why doesn't ARP supply the kit with the right (or best) sized washer anyway?
                            Or are they supplying some universal stuff?
                            Thankfully we have forums like this, which are like Audi learning books
                            • auditude
                              • 407
                              I'd say it's probably a combination of cost/efficiency and ignorance. Once they know about the problem, their response will be the true indication of their merit.
                              Kenneth
                              1990 Coupe quattro
                              1991 200q20v x 2
                              1998 Honda VFR800FI
