Arp
  • martinjs
    • 3205
    I thought i used the washers that ARP supplied but i can remember now, i cut the heads of the original bolts and used the original washers.
    • auditude
      • 407
      Originally posted by auditude
      I'd say it's probably a combination of cost/efficiency and ignorance. Once they know about the problem, their response will be the true indication of their merit.
      I received a reply from the contact I made to ARP. I'm going to work with them to get a better washer included in the application for our stuff.
      Kenneth
      1990 Coupe quattro
      1991 200q20v x 2
      1985 4ksq 20vt project
      1986 Coupe GT 10vt project
      2006 Honda Ridgeline
      1998 Honda VFR800FI
      • Pembo
        • Aug 2004
        • 295
        Does this help? It shows the Audi washer on the left and the ARP one on the right.
        Pembo
        quattro - Original 4WD rallying
        Rally Car photos
          I wonder if ARP uprated their washers? I'll have to check mine when they arrive.
          • auditude
            • 407
            Wow, I forgot about this thread. I guess I should update my last post to say that nothing ever happened with that.
            Kenneth
            1990 Coupe quattro
            1991 200q20v x 2
            1998 Honda VFR800FI
              Hmm o.k I'll have to invest in some SQ washers, does anyone know the ID of the SQ washers?
              Are they 11 or 12 mm?
              • NoNonsense
                Forum Sponsor
                • Apr 2004
                • 673
                #22
                No you won't. Your kit will have the correct bits.
                Joe "NoNonsense"
                axis motorsport
                joe@axismotorsport.com
                "At the end of the game, the king and the pawn go back in the same box."
                  Do you know something I don't Joe?
                  • NoNonsense
                    Forum Sponsor
                    • Apr 2004
                    • 673
                    #24
                    You know that I know that you know that I know....
                    Joe "NoNonsense"
                    axis motorsport
                      Pembo, Anle's post had measurements of the washers is there any chance you could measure the SQ washers and post them up?
                        Well now I know that you know that I now know that you know something I don't
                        • Pembo
                          • Aug 2004
                          • 295
                          ARP size
                          Outer diameter 19mm
                          Inner diameter 11mm
                          Thickness 3mm
                          Audi washers p/n 035 103 377 12 off £1.03 each
                          Outer diameter 22mm
                          Inner diameter 11mm
                          Thickness 4mm
                          Pembo
                          Rally Car photos
                            Pembo your a star! thanks
                            Nononsense obviously knew something he has measured the Eurovan washers in the ARP kit and they are 22mm.
                            I bow to his knowledge.
                            • Anagonda
                              • Aug 2005
                              • 70
                              I found a cheap way to get bigger washers.
                              Had a 2.5 liter (12valve) engine from a BMW E30 in garage and took it's original washers!
                              The bmw washers where even slightly bigger than original 3B washers. I don't know if the bmw washers will fit all bolts, because I only used 4(I had lost original four 3B washers somewhere). I'm just thinking that at front the washers might hit the cam chain, but I'm not sure.
