I thought i used the washers that ARP supplied but i can remember now, i cut the heads of the original bolts and used the original washers.
Arp
I received a reply from the contact I made to ARP. I'm going to work with them to get a better washer included in the application for our stuff.Originally posted by auditudeI'd say it's probably a combination of cost/efficiency and ignorance. Once they know about the problem, their response will be the true indication of their merit.Kenneth
1990 Coupe quattro
1991 200q20v x 2
1985 4ksq 20vt project
1986 Coupe GT 10vt project
2006 Honda Ridgeline
1998 Honda VFR800FIComment
Does this help? It shows the Audi washer on the left and the ARP one on the right.
Wow, I forgot about this thread. I guess I should update my last post to say that nothing ever happened with that.
Kenneth
1990 Coupe quattro
1991 200q20v x 2
Joe "NoNonsense"
axis motorsport
joe@axismotorsport.com
"At the end of the game, the king and the pawn go back in the same box."Comment
You know that I know that you know that I know....
Joe "NoNonsense"
axis motorsport
ARP size
Outer diameter 19mm
Inner diameter 11mm
Thickness 3mm
Audi washers p/n 035 103 377 12 off £1.03 each
Outer diameter 22mm
Inner diameter 11mm
Thickness 4mmComment
I found a cheap way to get bigger washers.
Had a 2.5 liter (12valve) engine from a BMW E30 in garage and took it's original washers!
The bmw washers where even slightly bigger than original 3B washers. I don't know if the bmw washers will fit all bolts, because I only used 4(I had lost original four 3B washers somewhere). I'm just thinking that at front the washers might hit the cam chain, but I'm not sure.Comment
Your kit will have the correct bits.
