'91 Audi Coupe 7A Rear of Engine Oil Leak
  • cgharibo
    • Aug 2011
    • 165
    I have a 1991 Audi coupe with the 7A engine that has 340,000 miles. The car has developed a nasty oil leak at the rear of the engine and I cant tell where it is from. It is not the valve cover gasket.
    The car loses 1 quart oil every 700-800 miles with a small pool forming at the rear of the engine. It is not power steering fluid.
    Does anyone have any ideas on what this engine oil leak may be?
    Is there a complete seal/gasket kit for the 7A engine so that when I am in there I have everything I may need?
    Thank you!
    • Dec 2017
    • 5991
    Where is it dripping from underneath?
    Could be sump gasket, rear main oil seal or somewhere else and tracking back.
    • John.
      • 2615
      Something like this,
      Bottom end kit..... GASKET SET CRANK CASE 08-29178-01 FOR AUDI 3B/ABY/AAN/ADU/RR 2.2L 7A 2.3L 5cyl | eBay
      • cgharibo
        • Aug 2011
        • 165
        I think it’s the rear main oil seal. What do I have to remove and take apart to gain access to the rear main oil seal?
        The steering rack is leaking a little and the clutch is original. Should I change the rack and clutch while I am there?
        This site is great!!
        Thank you everyone!
          • Dec 2017
          • 5991
          Is it a Quattro?
          Gearbox out job to do rear main seal. Easier if its not a Quattro. Do the clutch at the same time for sure. At the same time do the gearbox shaft seal and fit a new genuine slave for the clutch.
