Hi,
I don't know if someone has already done this mod?
When I was putting my little 'lash up' together I could'nt believe how crappy that O-ring is as a seal for the IC to the crossmember pipe.
This is what I used as an alternative, it uses a reducing straight length of silicone pipe (70mm to 60mm), this has to be carefully cut back until it fits, as it has to be fairly short in order to fit. It's also been fitted to Steve's car outside the rolling road as his O-ring was leaking badly on the day and the factory that makes the hoses (SFS) is next door!
I think its safe to say that we have both tested it fairly rigorously with regard withstanding high boost levels
I'll attach a picture of mine here and Steves in the next post.
Mark.
Mark.
