Bosch Spark Plug Break Down
    Bosch F5DP0R spark plugs
    F = M14x1.25
    5 = Heat range
    D = Thread length / Spark Position- 19mm / 17.5
    P = Platinum
    0 = Deviations from basic design
    R = Burn off Resistor
  • Fat Audi 80
    • 10547
    Nice.
    The Perfectionist
      Jamo - you are turning into a right friggin anorak m8
      Good info though !
        Lol it's what projects do to you, you end up researching a load of stuff for little issues!
          F = M14x1.25
          5 = Heat range
          P = Platinum
          R = Burn off Resistancce
          Great find Jamo.
          Just one thing: If I read the Bosch info correctly, the "R" is "Burn off resistor" not "resistance".
            Edited
            • PeteRR
              • 1326
              You had me worried there for a minute Jamo. From your thread title I thought you'd had a terminal issue with a Bosch plug.
              Good find though.
                To add a bit more to this thread...
                F = M14x1.25
                5 = Heat range
                P = Platinum
                Heat Range = 5... Lower numbers mean a colder plug... These provide higher heat dissipation into the head, and therefore lower heat absorption into the plug itself
                It would be interesting to try a 4 in a modified S2 - though worth remembering that Audi / Porsche / Bosch kept the same plug in the 315bhp RS2. However I don't think that Bosch have anything colder than 5 that gets fitted to road cars - 4 and below gets into their racing range I think.
                A plug that runs too cold will not clean itself properly.
                The 'D' defines the shape of the electrode and its position. The 19mm height is important... There is a 'C' code with a lower profile electrode that is of interest.
                A quick look thru some websites finds a Bosch F4CS which might be worth a go... Note the 'S' is for a silver centre electrode - not as hard wearing as platinum.
                I've found some high spec Iridium (allegedly better than platinum) electrode plugs made by Denso which claim to be alternatives to the Bosch items...
                Denso IK22 = Bosch F5DP0R
                Denso IK24 = Bosch F4CS
                There is also a racing application with IK02-24
                Just to be clear though - I have never used them... Just cross-referencing the info... A slightly colder plug might give greater knock resilience on monster boost machines.
                • merlin's S4
                  • Jan 2005
                  • 1539
                  I tried a set of the Denso Irridium plugs, don't know which part # but the S4 didn't like them at all!!
                    Thats not really useful info if you dont know the part number...
                    • merlin's S4
                      • Jan 2005
                      • 1539
                      Well they were listed for the S4 and I would assume they're supposed to be a straight swap for the F5DPOR so I'd hazard a guess that they were the IK22. I wasn't just trying a random set of Denso plugs!!
                      • Mikes2
                        • 1704
                        WR quattros used W4DPO Bosch plugs so it's not race applications only for a '4' heat range
                        Mike
                        http://www.s2-audi.co.uk
                          OK - thats good info then - I couldn't find anything less than 5 on-line ... but I found a new source of Bosch info tonight so that needs proper analysis.
                          • GazzaG60
                            • 4133
                            ive always used sparkplugs.co.uk. they stock lots at good money
                            anybody any experience with BK7re plugs on the I5. they are the recommejnded plug for 16vt's. W4dpo's are used by polo G40's too i believe W6dpo is the G60 plug
                            • S2_Dave
                              • Aug 2005
                              • 456
                              Does anyone know what the tip diameter is for F5DP0R?
                              David
                              '91 3B S2 Coupe
