Hi All,
Just about to have the Sedan converted to RS2 spec and need to make sure i'm covering all the right bases whilst the engine is out. Question is, what parts should I replace and what should I leave? The engine has done just over 70k miles, has no known issues, the clutch is strong, has had a replacement ps pump fitted (the bay is suffering from the usual ps pump seal failure I.e fluid in most places and covered in general road crud..) and will have the block, Inlet Manifold, cam and coil covers cleaned and refreshed.
The parts I have got so far are:
RS2 turbo - OEM Refurbished
Wagner Evo Em
RS2 Injectors
RS2 Inlet Manifold
3" Downpipe - The GB one
Full set of Black Samco Boost and Water hoses
Full Gasket set.
Cam Position Sensor
The parts I still need:
Fuel Pump - 044 Bosch
Exhaust
Head studs - Need these quick if anyone has a set.
The parts i'm not sure if I should replace:
Water pump
Oil pump
Sensors - (I've got a CPS to fit)
Seals - Which ones?
Would appreciate any input on this bearing in mind i won't be doing any bottom end work or balancing.
The intention is to basically get the engine bay looking spot on and clean and to release a bit of the engine's potential with a standard RS2 upgrade without going mental and keeping as much OEM'ness as I can.
Russ
Wagner Evo Em
RS2 Injectors
RS2 Inlet Manifold
Full Gasket set.
Cam Position Sensor
Exhaust
Water pump
Oil pump
Seals - Which ones?
Russ
