The idea is that the flowing exhaust gases will cause a vacuum in a pipe Y'd into it. This will draw the gases from the outlet of the catch tank, out the exhaust.
Oil Catch Tank Please
Yeah. I've got just an air filter on mine. Some oil vapour still comes out though. That's the idea of taking it out through the exhaust. You don't get the stink when you're stopped with the engine running.SSComment
Mine vents into the air con drier under the wing at the minute. Still smells when stationary. I'm having a plate made for the downpipe so I can feed it straight in there. (like Doug has done). Also means I can have a wastegate exhaust so I can make lots of noise
Benthe best intentions are fraught with disappointment - gil grissom
1994 ABY Avant - it's getting thereComment
So what should be the dimentions?
How many buffles?
Does this Downpipe system works? Has someone it working?
Is this valve mentioned in this thread a part of the oil fumes system?
Please answer these questions!Go Holset or Go RS4Comment
