Just had to replace the oil cooler on my ABY coupe cos it was leaking. Wasn't prepared for what i found
The cowling that is supposed to channel cool air to the cooler is made of what looks like old fiat panda, or at least it rots the same. It had completely corroded and when i tried to remove it it turned to dust
Also the mount that connects the cooler to a hanging bracket was the same.
But the thing that really bugs me is that it was so rot it had started to corrode the coolers lower edge, and it was now leaking
As you can see the lower edge has been eaten away and you can see whats left of the mount once i'd ripped it off, no persuading needed.
Also the mount that connects the cooler to a hanging bracket was the same. But the thing that really bugs me is that it was so rot it had started to corrode the coolers lower edge, and it was now leaking
