oil cooler, check it ain't rotten
  • Crawford_S2
    • 1555
    Just had to replace the oil cooler on my ABY coupe cos it was leaking. Wasn't prepared for what i found
    The cowling that is supposed to channel cool air to the cooler is made of what looks like old fiat panda, or at least it rots the same. It had completely corroded and when i tried to remove it it turned to dust Also the mount that connects the cooler to a hanging bracket was the same.
    But the thing that really bugs me is that it was so rot it had started to corrode the coolers lower edge, and it was now leaking
    As you can see the lower edge has been eaten away and you can see whats left of the mount once i'd ripped it off, no persuading needed.
    Ragusa Coupe gone!
  • Crawford_S2
    • 1555
    picture of shiny new one
    Ragusa Coupe gone!
    • Crawford_S2
      • 1555
      This is where it goes, the plastic tube holds wet leaves nicely so the steel surround can disintagrate at its leisure without the owner noticing.
      Ragusa Coupe gone!
      • Crawford_S2
        • 1555
        New bit in situ, only 180 ish from the VAG part gang
        Mate made the new bracket out of 4mm ally sheet so it don't disappear again, why Audi didn't make it out of something sensible in the first place i don't know. Also note gap left for wet leaves, debris, e.t.c to fall out and not attack the new cooler. Leak fixed, happy
        Ragusa Coupe gone!
        • horvathg
          • Dec 2003
          • 556
          I have seen this before...........on Russian Ladas.....
          Groofo, it looks shyte and dreadful. And could cause fatal eingine oil starvation if unnoticed. Lucky you didn't have to replace the oil ducts too. They are kinda costly...
          Gabor
          96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
          • Crawford_S2
            • 1555
            Shyte, yes thats what i thought
            Ragusa Coupe gone!
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              When I first had my S2, I had a leaky oil cooler. I left an anti rust coating over everything. When I tightened up the hose connection, that turned out to be loose, and cleaned off the oil, it all looked like new.
              SS
              • curlyks2
                • 1069
                General rubbish (dirt, fallen leaves, etc) tends to collect in the airway to the oil cooler... this will hold in the moisture which is really not wanted. It's a good idea to clear out the oil cooler airway every now and again!
                Ck.
                Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
                • WabTheKing
                  • May 2004
                  • 2567
                  aluminium still disintegrates, especially if its touching anything thats steel because over time it oxidizes and turns to dust so if you havent treated the ally with anything you wont have gained anything over making it out of bare steel so id atleast paint it with something, to get the longest life it wants anodizing but i would just paint it
                  • S2-racer
                    • May 2004
                    • 247
                    it looked as though the oil cooler on my car had split, didnt look to corroded.
                    still, it aint leaking now!
                    think im gonna need to put notes in a diary or somethin, "check for leaves, etc in oil cooler duct"..... lol
                    '92 S2 - Bent now
                    • Crawford_S2
                      • 1555
                      Will treat it to a coat of something when i get time but had to fit it in a hurry to free up the ramp yesterday, fuel pipes on a nice RS2 had rot to powder too in the moisture trap behind the heatshield for dp! It must be catching!
                      Ragusa Coupe gone!
                      • NoNonsense
                        Forum Sponsor
                        • Apr 2004
                        • 673
                        looks great, groofosp! you should have taken the opportunity to put a larger oil cooler in, no?
                        Joe "NoNonsense"
                        axis motorsport
                        joe@axismotorsport.com
                        "At the end of the game, the king and the pawn go back in the same box."
