90 20v nearly cained by a tt sport
  • AUDI9020V
    • 653
    i know i dont have a s2 but well on the a59 last night to harogate n behind a tt,anyhow came to the old audi garage roundabout and he floored it so i followed him it handles corners like its on tracks,
    but he only kept about 100 yards infront of me and was catchin him,then he slowed right down.not bad for a 15year old car,but how do i get more grunt out of the 7a engine.also just changed the oil n filter tnight and after 7000miles it was black as tar and only got 3.5litres out and i think i put 4.5 in the last time infact i know i did,should i change it more.
    1990 100 2.2 10vqt 82k miles(now dead)
    1990 90 2.3 20v 166k miles
    1988 90 2.0 10v 181k miles
    oh and a polo for work.
  • pastures16
    • 2058
    get some boost
    94 s2 avant
    aoc member 1116
    • AUDI9020V
      • 653
      hows the best way to get some boost on it,after the oil change its runnin alot better.
      • elijahallens2
        • Aug 2004
        • 310
        Get a thick head gasket to lower compression and add a turbo exhaust manifold and some wiring and your boosted. Be careful though, the stock internals can only handle maybe 300hp on the 7A engine.
        Elijah
        91 Audi Coupe Quattro- AAN engine transplant
        • charlie
          • 447
          GET UR INJECTORS CLEANED ULTRASONICLY. BEST £75 QUID
          U WILL EVER SPEND ON YOUR CAR. ALLOWS FUEL TO ATOMIZE
          AND HENCE CREATING MORE TOURQUE.
          RS2 MTM
          • charlie
            • 447
            OIL FILTER TAKES UP 1/2 LITRE. I NORMALLY FILL UP OIL FILTER
            BEFORE PUTTING IT ON. HELPS REDUCE TIME IT TAKES FOR OIL
            PRESSURE TO BUILD MINIMISING WEAR.:mischeif:
            RS2 MTM
            • Billman
              • 4129
              To get boosted you also need a turbo!
              Go Holset or Go RS4
              • charlie
                • 447
                Or Nos?
                RS2 MTM
                • rotoryboy
                  • May 2004
                  • 3281
                  Or a supercharger
                  Mark
                  Race Clio RS197
                  S2 Coupe ABY (Green) - RIP
                  S2 Coupe ABY (Blue) - Sold
                  • pastures16
                    • 2058
                    hey maybe he should by an s2
                    94 s2 avant
                    aoc member 1116
                    • ottawa coupe
                      • 856
                      ^-------- yep! much cheaper and easier in the long run! it's the reason i didn't go crazy on my coupe this summer. canada has a 15 year exemption rule which means after 15 years, any car (with exceptions of course) can be legally imported. if i were to go turbo, i will import an s2. it will have the built in quality that is very difficult to replicate in the aftermarket without spend huge sums of money. you also get all the other upgraded bits like suspension and brakes which are able to keep up with the power better.
                      basically, always cheaper to buy than to build so if you can buy it, buy it!
                      1993 UrS4...aka the rocket powered living room
