Audi 80 2.0T
  • Wizard-of-OD
    • 926
    • Home: Syria Current: Canada
    Audi 80 2.0T
    no longer a project
    Issam N. Abed
    iABED Industries
    iABED Email | Facebook
    The build thread
  • S2 Ant
    • 3682
    Welcome to the forum, you've come to the right place for info and advice, you'll find everyone on here very helpful and knowledgable!
    Ant
    2011 Kawasaki Z1000
    • Wizard-of-OD
      • 926
      thanks
      question...do i have to have a site with my pictures uploaded on it or can i insert pictures straight from my computer?
      because i want to upload my picture
      Issam N. Abed
      iABED Industries
      The build thread
      • SteveH
        • 4460
        You're limited to 100kb to upload pics. if you have pics online somewhere else post a link to them.
        91 Modded 3B
        14 A6 Avant Black Edition
        • Wizard-of-OD
          • 926
          never mind,just saw the function.
          Issam N. Abed
          iABED Industries
          The build thread
          • Vagsport
            • 533
            Nice car, welcome to the madhouse!
            Siena
            • Wizard-of-OD
              • 926
              Siena
              from what i hear,your the maddest of the patients
              you put oil in your cereal
              Issam N. Abed
              iABED Industries
              The build thread
              • Vagsport
                • 533
                Just a suggestion, Wizard, it would be a lot better to use the 1.8 16V engine from the Golf Mk2 (KR / PL). These have oil spray jets to cool the underside of the pistons, which the ABK won't have. It is also best to keep the bore size to 81mm, yours is 82.5mm - a bit too large for reliable sealing as far as forced induction is concerned. Metal headgasket for Golf G60 is best used.
                Going down this route will also enable you to use the S2 exhaust / inlet manifold, after having #5 port removed from both and resealed. Pistons for the S2 - stock and aftermarket can then be used, rods also. KR engines can be picked up for as little as €200. The 3B loom / ECU can also be modified to run 4 cylinders, you'll need to get a suitable triggle wheel for engine RPM and rig up a TDC sender - on 4 cylinder engine easier at crank pulley end.
                Siena
                • Wizard-of-OD
                  • 926
                  Hey Vagsport
                  well my block does have oil ports to cool the pistons.I have pictures of the block to show.
                  I wouldve gone 20V head and done but the problem is i have allready purchased an 8Valve head.
                  Would be a complete waist to not use it.....sigh.
                  I am going full out on management to get rid of my MAF.Going with 034EFi.com
                  my biggest problem right now is an exhaust manifold that can be built to my specs....
                  Issam N. Abed
                  iABED Industries
                  The build thread
                  • Wizard-of-OD
                    • 926
                    deleted
                    Issam N. Abed
                    iABED Industries
                    The build thread
