Since a lot of you have helped me throughout the years with my car it is not more than fair I share when I have some success.
Went to Jonus for a whole day mapping session and the results are in on E75:
387 w-Hp & 537 w-Nm.
Approximately 480 ish Hp 640 Nm at the engine, as I was informed.
It was around 300 whp on E15 (or 98 octane petrol + a little ethanol if you like) if I remember correctly.
What's the recipe you ask?
Well I've got most of the parts from this forum actually, thank you all for good deals!
Engine:
AAN block rebuilt, line honed, honed cylinders, crank weighted and balanced.
New rings
OE pistons
FCP Engineering x-rods
ADU bearings
10.9 main cap bolts
7A flywheel
7A head overhauled & repurposed for ABY use
ADU cams
ADU cam sprocket
ADU inlet manifold
ADU exhaust manifold
ADU turbo with billet compressor wheel and cutback exhaust
ARP head bolts
Sachs organic race clutch
880 cc injectors from Finjector
TFSI coils
Samco/Roose hoses
Wagner evo1 intercooler
044 pump relayed
4 bar FPR
MAC wgfv
Tial Wastegate
Billet sprocket at crank
3 inch exhaust from turbo
MaxxECU with knock sensors, flex fuel sensor and fuel pressure sensor
The power is really intense coming from spring pressure and safe map for a long time.
Thank you all that has contributed on here!
You are too many to mention without the risk of forgetting someone.
Engine:
New rings
OE pistons
ADU bearings
10.9 main cap bolts
7A flywheel
ADU cams
ADU cam sprocket
ADU inlet manifold
ARP head bolts
TFSI coils
Samco/Roose hoses
044 pump relayed
4 bar FPR
MAC wgfv
Tial Wastegate
