My 96 ABY S2
  • #16
    Little update on the underside refresh. It grew arms and legs. (Why would it not ) from it needing attention to the exhaust hanger closest to the rear panel. It became evident that water ingress due to the breakdown in the seam sealer had riddled the underside.
    So the decision was made to drop all rear running gear, suspension, prop, fuel/ brake lines and get right in there. Some areas just required taking back to clean steel. Where as two needed new metal. (Rear of the sill and as mentioned, the exhaust hanger)
    We’ve used 3M Sealer, and it’s back in body colour. Apologies I don't have pictures in body colour. I'll add the later when home. Here’s are a few of, before, during and after.
    We’ve done to the outer sills, up to the gearbox tunnel. This point forwards we’ll complete when the engine/ box comes out.
    Stuart
    Stuart
    B2 90 quattro with boost
    • #17
      Looking really good mate!
      What's happening when the engine comes out?
      Jase.
      • #18
        Yes looking good keep up the great work
        Sent from my SM-G973F using Tapatalk
        ABY Cricket Green Pearl Coupe, blk leather
        THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
        • #19
          Jase.
          Just a freshen up of the engine bay buddy.
          Stuart
          • #20
            Thanks buddy..
            Stuart
            • #21
              Not a great deal to update with. But I’m progressing with the underside refresh. Removal of the both subframes which have been sent for blasting/ dipping and galvanising is in hand. Suspension and wishbones will be placed to one side ready for the cast type and some freshly refurbished pressed rears. I’ve a new set of KW V3’s waiting to be fitted.
              As with these S2’s. I was kind of hoping to removed the suspension and subframes ready for the change over. But no such luck. Found some surface rust in the wheel arches that needs attention prior to suspension fit up and wheel alignment.
              I’ve refurbished the a rear hub and carrier fitted new bearings etc. I used x3 coats of high build primer. And x2 coats of smooth Hammerite. Didn’t fancy the Por 15 route this time around. Or trusting a company to plastic coat the hub carrier without covering the bearing seat with paint.
              Next time home I’ll see to the wheel arches with a wire wheel attachment. Pop some fresh 3M under seal in there. Plus send the rear hub assembly down to Alex (Error 404) at Ultra Performance Engineering to make up some front and rear caliper mounts for the front AP’s and my Ur S4 calipers I’ve robbed from my 90q drag car. Picture of a two piece disc set up that will be fitted front and rear.
              Cheers all.
              Stuart
              • #22
                Stuart
                • #23
                  Subframes back from galvanising. Should be good for another thirty years I hope.
                  Stuart
                  • #24
                    Looking good!!
                    • #25
                      Looking good!!
                      I'm home next week for a month if you want to call round for a cuppa.
                      Stuart
                      • #26
                        Where and how did you get them galvanised? Presumably hot dip? Asking for a friend..... (with bigger subframes!)
                        • #27
                          Sounds good to me! I'll drop you a PM.
                          Jase.
                          • #28
                            Done by these guys here at Ribble. https://paint-strip.co.uk
                            Stuart
                            • #29
                              I still hate that I sold this but glad that it's gone to someone capable of such work.
                              I always look forward to the updates on this, it is looking amazing!
