Some road tests RS2
  • A80Avant
    • 10873
    • Country: Greece
    Some road tests RS2
    hello,
    today we went to a private road,for some tests with the greek audi sports club,and i was a part of it!We used the AX22(which uses GPS signal) and the Gtech equipment although they are known to not be that accurate(that was only available),and here are the results!
    0-100----> 5.86sec
    200m----> 9.48sec
    400m----> 14.39sec (speed:162.29Kms)
    60-160--> 10.9sec
    I still havent got around in having my car checked for the 2 leaks i have,water and oil (small ones,no putt made from them),and also the boost leak im hearing.
    The car produces 1.5bar until the 5500rpm or so mark and then drops to 1.2 to the red line in the last 3 gears
    My clutch smelled quite a bit from the second run,it still smells when i ride the car but the smell slowly goes away.I hope i havent done too much damage to the clutch... Gears go in nicely though and i have no slip....Actually how brutal can you get with these stock clutches???Mine was new,only around 4000Kms on it
    what do you guys think?
    cheers
    Vasilis
  • GT500
    • Jun 2006
    • 2181
    sounds like you just beded it in! Standard clutch can take quite alot of abuse!
    Good figures!
    Rob..
    87 UR 20v ABY
    97 S6 Avant
    • YELL MAN
      • Dec 2005
      • 535
      • Country: Shetland Islands
      How does the G-tech work on the car is it plug and play or does it have to be wired in?
      1994 Indigo Blue S2 coupe
      1994 80 Avant 1.9 TDI
      2005 Yamaha Fazer 1000
      1953 AJS Model 18S
      • A80Avant
        • 10873
        • Country: Greece
        it uses power from the cigarette lighter.it uses some kind of data card that passes the results on the laptop there on
        • YELL MAN
          • Dec 2005
          • 535
          If thats all it plugs into how can it know road speed and quater mile times
          1953 AJS Model 18S
          • A80Avant
            • 10873
            • Country: Greece
            GPS system!!
            • YELL MAN
              • Dec 2005
              • 535
              Ah i see i will have to look into getting one
              1953 AJS Model 18S
              • A80Avant
                • 10873
                • Country: Greece
                it is not that expensive,i think it costs somewhat around 250GBP.But it is said that people that have done repeated tests with this one and the VBOX,it seems that the Gtech gives a +0.5 to +1sec in measurements.Judging from that i could say that im around 5sec the 0-100Km more or less...
                • A80Avant
                  • 10873
                  • Country: Greece
                  correction,the Gtech doesnt use the GPS signal,the AX22 does.
