hi all my cars being doing this for a while now on and off, problem is when u flat the accelerator at the end of the rev range it starts to splutter as if theres not enough fuel gettin in , also watchin the boost gauge it goes past 20 psi to approx 23 most when runnin normally it hits 20-21 psi any ideas chaps, btw theres always fuel in the tank
problem spluttering at high revs
Doubt its fuel but could be, i would go for a set of plugs first, could be a missfire.Ragusa Coupe gone!
vw T5 Kombi. In the process of being "ruined" -
nip: You didn't say whether your car is a 3B or ABY. Regardless, I suggest that you might want to read this:
http://forums.audiworld.com/s4s6/msgs/149788.phtml
Its geared to the AAN and ABY engines but there might be some things there to help you if you have a 3B.
Dave F.RS2'd 93 UrS4 5 spd sedan
sorry s4boy its a aby,thanks for the advice, funny that a few weeks ago i took the plugs out and gently cleaned them then it ran fine again, but i did notice that the end of the coil packs on cylinder 1-2 the boots were ripped at the end the plugs look exactly as u explained light brown white tips.
i think im gonna buy some plugs tomorrow thanks matey
so then nip i take it you got rid of this problem in the end what was it as it seems to be like mine is at the moment ...Comment
well i left the other day ( after rolling road ) on all five cylinders except for when you gave it some spuds got home looked at my coils id put on the other day and one looked mankey so i changed this for a new one i had ages ago ... id already changed the boots.. this made it much better ... then i thought hang on il chop out all the old wiring put new wires in and see now it goes then... three hours later the missfire is back again although not as often or as bad but its there and it wasnt before.... so im starting to cry ..
now i am wondering if i should change the spark plugs but there ment to last for ever arnt they...
