Performance figures
  • dest
    • 4287
    Ill let you work it out
    • T2Andy
      • 1903
      Nothing is perfect when man and machine come together ,but you do get a good
      idea when said equipment is used.
      • Audi_CQ
        • 940
        • Country: Norway
        I've used a G-tech RR for a while so I know it works(and how ) , but I'm curious if you can back up what you are posting: "Be realistic, a Gtech is never going to be perfect or very accurate" , or if you're just asuming/have read/............
        • dest
          • 4287
          Read my post again, I never said they were totally useless, just not 100% accurate
          • S4turbo
            • Nov 2005
            • 81
            • Country: Norway
            #20
            Dest, If you are serious about your claims, back it up with information, if not please stay away from putting your personnal opinions here. There are a number of shortcomings with the Gtech yes, but what? The idea here is to share knowledge, now please do.
            J
            • dest
              • 4287
              Chill out FFS!!
              I will type it again in plain english.
              A Gtech is ok but will never be 100% accurate.
              Therefore, take any figures with a pinch of salt.
              If they were 100% accurate, why do magazines etc spend thousands on Datron or similar equipment?
              I really cant put it any simpler than that?!
              God you lot on here are bloody highly strung sometimes!
              • jogi730
                • 2335
                THose figures look great to me - even if they are .5 sec out.
                Well done Mr Jones. Be good to see her in the flesh and on the move.
                Chris
                Audi 90 quattro (Typ 85)
                20v turbo conversion
                • DJones
                  • Jun 2005
                  • 2020
                  Your right nothing is perfect and the Gtech is no different. Out of interest i also have a 5L GT40 and a 7.5L Cobra (i don't mention them here as this is not the right forum) both have been to MIRA and the Gtech is as close as mentioned above when taking calibration runs, so long as you input the correct weight.
                  My neighbour has a weighbridge, i measure them on that prior to taking the readings so I'm personally pretty impressed with the accuracy from the Gtech as MIRA are not known for there inaccuracy's.
                  Without sounding rude or highly strung if you have a better way of measuring the engine performance i would welcome your knowledge and would be happy to pay for accurate results.
                  • Pirvu Eugen
                    • Apr 2007
                    • 1978
                    • Country: Romania
                    #24
                    Wow! Nice After this i am looking... ~400 hp and more low down torque for drivability.
                    Well done!
                      Looks brilliant what is the spec of this car BTW?
                      • DJones
                        • Jun 2005
                        • 2020
                        Originally posted by S4turbo
                        Great numbers,
                        can you post the Gtech file? What is your setup (hardware)?
                        Best regards, Johan
                        I'm struggling to load the graph but will keep trying. I use a Gtech pro RR.
                        • DJones
                          • Jun 2005
                          • 2020
                          Thanks, the spec is:
                          AAN block, pouter rods with decked pistons taking the cr to 8.5. Lightened flywheel and front pulley.
                          The head is ported and polished and I'm using the 7a ex cam. Orange injectors with an 034 inlet manifold.
                          The turbo is from turbo dynamics it is a hybrid GT30 which is the secret weapon on this car.. never been more impressed with a turbo. Its mounted to an RS2 ex manifold. The exhaust is 3" turbo back (home made)
                          It utilises two intercoolers with water injection on the exit of the last intercooler. all of the inlet tract is 3" with the MAF mounted on the positive side of the turbo.
                          I was never really interested in building a high horsepower car though the spec of the engine will take it i wanted to build it for high torque with a wide window of power as it is a road car. I certainly achieved that.. it will break traction in 1st 2nd and 3rd when the boost comes on and you can easily achieve progressive power slides.
                          I have driven variants with high horse power engines and although ultimately quicker than mine they would still be trying to catch me at 80-90mph at which speed you have proved your point.
                          • dest
                            • 4287
                            As you can imagine, not everyone has a weighbridge next door, so people are using factory spec figures quite alot, and therefore getting inaccurate results etc.
                            Once again, I never said they were crap....
                            • AndyP
                              • 6049
                              If I wanted very accurate results I would use Datron timing gear or similar.
                              Be realistic, a Gtech is never going to be perfect or very accurate.
                              Just remind me, how much is a Datron?
                              • Fat Audi 80
                                • 10547
                                Go to your local recycling centre, pay £5 and collect your ticket
                                In answer to your original statement, I think we are looking at an accuracy of 95 - 98%, which in my book is good enough for pubs and forums.....
                                Cheers,
                                Steve
                                The Perfectionist
