My car will not start
  • audiman
    • 4827
    Dean sounds like it is the hall sender, i suspect that when its not running you have no spark. It is fuelling as the crankshaft sender in the gearbox bellhousing is working. Not sure if its possible to fit a new one without removing the camshaft sproket. Most cars this has to be taken off to allow access.
    ABY owners?
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • Mark Halligan
      • 2001
      ABY owners?
      Yep, the cam sprocket needs to come off to get at it.
      Mark.
      Mark - Modded
      • audiman
        • 4827
        Check with Martyn at VAGparts or your local stealer. Part number is 034 905 161. Go get one tomorrow. They may have it in stock. Sure you can get it fitted for this weekend.
        Audi UR Quattro
        • jubjub
          • Nov 2003
          • 1239
          Mark.
          How much of a job is this then
          • audiman
            • 4827
            Aux rad moved out of the way. Aux. belts off, top cam belt cover off, set engine on TDC. Undo the cam pulley bolt and pull off the pulley. Change hall sender and refit in reverse order.
            Audi UR Quattro
            • Doug_RS2
              • 3847
              #21
              Bring tools to Billing and we'll get it done there. Include a large adjustable spanner so we can lock the camshaft.
              • audiman
                • 4827
                Good point, once running it wont die unless you switch it off. If you get the new part bring it along with you. Myself or someone else will fit it for you. Or just watch and laugh at you trying
                Audi UR Quattro
                • jubjub
                  • Nov 2003
                  • 1239
                  Trying being the operative word. I'm all fingers and thumbs me
                  • jubjub
                    • Nov 2003
                    • 1239
                    Tried to start the car again this morning,guess what,would not start This is still the hall sensor,right? Is it just an intemitent fault or should it start when cold If i can get a sensor i might have to come to Billing on an AA truck
                    • Doug_RS2
                      • 3847
                      #25
                      On some of your pictures of the powder coated parts, you had the connector sticking up/mounted wrong - have you tried wiggling it in case it has been damaged? It is the one at the front of the inlet manifold beside the small vacuum hose.
                      When my sensor went, it occasionally wouldn't start when warm, then got gradually worse over 2 weeks and would occasionally not start when cold.
                      • jubjub
                        • Nov 2003
                        • 1239
                        Right, heres an update to this saga...
                        Had a new hall sender fitted on Wednesday, fine, the car started....I have a running issue which possibly may be the cam timing out,however that is another problem...
                        At the moment i am back to square one; this morning the car would not start again but when i got home tonight the car started again, and did so numerous times, so i ask what an earth is going on Am i correct in thinking its not the HS now? I suppose i should check and see if i am getting a spark, but then is there any point; If the car decides its going to start it will spark, if its not then it won't
                        Confused,Dean
                          #27
                          How do you know the wiring to the hall sensor is OK - maybe a fault on that which made the car appear to have a faulty sender in the first place. Pull fault codes 1st off.
                          Also - if the cam timing is far enough out you may be getting a nonsense signal from the hall sender which the isn't happy with.
                          Could also be something unrelated on the alarm or immo wiring.
                            Dean what was the cuase of this in the end?
                            I'm having strange starting problem that started at GTI and for the past week keep popping up where the engine just cranks but doesn't start.
                            Come next morning it starts
                            • Graham
                              • 1622
                              #29
                              Blocked fuel filter??, could this cause it to not fire.
                              • jubjub
                                • Nov 2003
                                • 1239
                                Was the fuel pump that was knacked.
                                PITA as the symptons were also that of a faulty hall sender, and that was changed first
