My UrS6 Avant
  • prj
    • Mar 2010
    • 6308
    So, here is what is going onto my car:
    * H-beam rods
    * "New" crank
    * All new bearings, gaskets
    * New OEM oil pump
    * New timing belt etc
    * Big MAF
    * Billet timing belt "cog" (sorry, don't know the english word).
    * Aquamist HFS-3 Water injection system
    Old oil pump has bits of the 2nd cyl rod in it, so it can not be used.
    I don't want to drop my CR and for the money I would spend on a FMIC, fitting a meth kit is way more bang for the buck.
    • Thuppu
      • 4115
      Ok, great you can test the Aquamist on your car and then I can also get one before mapping.
      • s2_wot
        • Aug 2006
        • 2178
        Shane
        • prj
          • Mar 2010
          • 6308
          Yes, you will get very good gains from W/I with your big turbo and stock CR.
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            #20
            I want something like this....in the competition
            • Thuppu
              • 4115
              Sounds good. How big advantage in do we speak of, approximately?
              By the way, you put H-rods... any plans for big power solutions? :mischeif:
              • prj
                • Mar 2010
                • 6308
                I put in H-rods because my 2nd cyl rod is toast anyway, and since I have to do a bottom end rebuild there is no reason not to.
                For now, I am keeping it with K26/K27 and W/I, because any other changes mean significant and expensive modifications - intake, exhaust manifold, downpipe, exhaust system, turbo oil and water lines etc...
                As for your car - we should be able to run upto 5 degrees more timing and about 0.5 bar more boost, but we will see that when mapping, there is no point to speculate now
                • Jonnybravo
                  • Aug 2008
                  • 2051
                  Sounding great Dimitri, keep at it.
                  • Mr.Woodaker
                    • Apr 2009
                    • 48
                    • Country: Norway
                    #24
                    Really nice Car Keep up the good work
                    1994 Audi S2 Saloon , , 1996 Audi S6 2.2T Avant , 2002 Audi A4 1.8T quattro , 2003 Audi A6 Avant tdi
                    X- 90 20Vt q , 3X 90 20V q , S6 plus limo ,2x Audi S6 V8 avant , S2 limo , 200 tq , 200 tq avant ,Audi S4 2.2T Avant ++++++++
                    • prj
                      • Mar 2010
                      • 6308
                      Thanks. Hope I can get it running again soon...
                      Currently busy mapping a few cars in the UK though:
                      • prj
                        • Mar 2010
                        • 6308
                        So, a small update...
                        My old crank was so bent that it did not even turn properly by hand anymore.
                        New crank turns perfectly and all bearing clearances are perfectly to spec, measuring with both a special tool (no idea how it's called in english) and plastigauge.
                        Block has been cleaned inside and out and decked.
                        Here a pic:
                        Crank installed:
                        The bores are almost unworn, you can still see all the factory honing. I am thinking of keeping the rings, because new rings were installed only 5000 miles ago.
                        Changing the heater matrix as well while the engine is out. Converted my ECU to big maf and machining the airbox and re-doing the intake to fit. Goodbye broken wires.
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          #27
                          Good luck,come on!
                          • JP
                            • 1858
                            Personally I'd run a flexhone down them for 10secs and re ring them with molybdenum inlaid rings for piece of mind. That way you run no risk of chrome breaking away from the top ring at high boost.
                            UrS6 Stroker + HTA3586 =
                            • prj
                              • Mar 2010
                              • 6308
                              Yeah, the block will be honed.
                              I found a pic of the old boxes from the old rings.
                              Says "NPR Europe" on them.
                              Which rings would you suggest? Could you give me a part number of some sorts?
                              • Thuppu
                                • 4115
                                Stock OEM ring a quite expencive... Didn't they use Golf GTI rings on these, if you want OE quality? Goetze is used much, I havn't heard any trouble with them.
                                Here is something: http://www.s2forum.com/forum/showthread.php?t=49069
