thts absolute pressure , meaning 0.7 bar, which is still to high!, either have a leak to wastegate somewhere, or its been upgraded?
1990 Audi 100 2.2 5cyl 10v turbo auto
yeh it will do, at that boost you will be close to 200 hp, dont really no anyone in your area , it may well have been chipped thts why your seeing tht boost, cos in stock form it should have overboost protection come in at 1.6 meaning 06.bar of boost
Standard boost is 0.38 bar on an MC2, so you see 1.4bar max on your digital display. If you see 1.7, then it is certainly tuned. Have a look at the wastegate too see if it is still closed at the top. They often screwed the WG in a bit, but that isn't the ideal way of boosting these engines.
MC had 0.4 bar
KG 0.6 bar
1B/2B 0.8bar
they come with an intercooler yes, which is a decent item.
Replace your michelin boosthose with a silicone one however, one day you'll be standing along the road with a popped hose
Originally posted by Avantus View PostStandard boost is 0.38 bar on an MC2, so you see 1.4bar max on your digital display. If you see 1.7, then it is certainly tuned. Have a look at the wastegate too see if it is still closed at the top. They often screwed the WG in a bit, but that isn't the ideal way of boosting these engines.
MC had 0.4 bar
KG 0.6 bar
1B/2B 0.8bar
Im gonna take it to a tuner, maybe dialynx or mrc tuning and get a rolling road tune up, i'll replace the hoses and anything else which maybe weak first.
Originally posted by salad.dodger View PostThanks for the info dude, i made a mistake, when on full throttle i see 1.4 not 1.7, why i thought i saw 1.7 im not sure
and had bout several things for it including the (Michelin man) boost hose as it gets called,
top rad hose, the metal coolant pipe that runs from the thermostat hosing along the block
and the little hose from this that goes to the after run pump.
The boost hose was on the the car 2 weeks before some ******** drove in to me and wrecked the car,
the other hoses have never even been fitted. You can have the lot for £30 +postage if you want them.
The Michelin man boost hose is ~£70 on it's own from Audi. All the parts are genuine from Audi dealer. Drop me a PM if you want them.
I also Have 2 MAC 14 ECU's if you ever need one or want one for doing mods to. £20 each.
Originally posted by driftin jo View PostI have some brand new parts for you engine you may be interested in, I had one a few years back
Originally posted by RWD19T View PostI was always under the impression that the MC's were fuel injected and the later k-jets where KG like my old Audi 200 which had half leathers and electric seats aswell may be wrong though.
If you want to boost more than stock I've still got an ECU with the zener diode mod on it somewhere on the shelf
cheers
