90 20v quattro, 25mm RARB and torsen
  • #16
    Would the easiest solution be to cut out the required, sleeve and weld?
    Sold ABY-stock
    • #17
      • #18
        Much better idea. I think only about 20-30mm would do it. I'll maybe try that with mine. I'll need to find a sleeve the right size or make something after checking the correct diameter.
        • #19
          How about sourcing shorter drop links, got to be cars out there with a 270mm drop link, ford focus ones seem to ring a bell at this length
          • #20
            I cut threaded and joined mine tonight. I'll get proper joiner nuts on it and figure out the best length. I cut 30mm out of it.
            • #21
              just buy some threaded sleeve, adjust to suit, then weld it. done
              • #22
                Why weld? Just use a jam nut at either end of the sleeve
                • #23
                  I'm going to pick up threaded sleeve(joiner nuts for threaded rods) tomorrow to see how it turns out. I was originally just trying to the the length right but I get lock nuts will just do it.
                  • #24
                    Job done. Shortened 30mm
                    • #25
                      Having only just got he car MOT'd and taxed from today. This is a perfect set up and extremely neutral from first impressions this morning... However I will wait and see for damp conditions
                      • #26
                        glad to hear it. iv had mine on the road for a few months now and it seems really nice compaired to stock 28 year old suspension. Bear in mind my typ85 90Q never had a RARB so was the door handles would try and touch the ground on hard cornering! keep us posted on any wet weather antics!
                        • #27
                          Having been under the car to fix an exhaust blow I noticed the arb had been hitting the body fairly badly
                          Sent from my iPhone using Tapatalk - now Free
                          • #28
                            What drop links did you end up with?
                            Sold ABY-stock
                            • #29
                              Audi 80 fronts, looks like I need something a little longer
