AMD's 200 20v - QUAT44RO
Love the sniggering/expletive's....
Thank you guys! I'm excited to have it back up and running after 8 months! Needs some things buttoned up and the boost can go up
'15 S3
'91 200 20v
'91 200 20v AvantComment
It sounds amazing, love it!
I've got a question for you - since you are using 01E 6 speed, which as far as i know is longer than the original 5 speed, what cardan shaft are you using? I mean the OEM shaft is too long for this gearbox, did you replace it and if so, from what? From V8 d11 4.2 manual maybe?Comment
The 01E is actually shorter than the 016 transmission by ~20mm. I slid the engine and transmission back as far as it could go and the driveshaft reached no problem.It sounds amazing, love it!
I've got a question for you - since you are using 01E 6 speed, which as far as i know is longer than the original 5 speed, what cardan shaft are you using? I mean the OEM shaft is too long for this gearbox, did you replace it and if so, from what? From V8 d11 4.2 manual maybe?'15 S3
'91 200 20v
I'm quite alright with thatSorry that I used your two photos, but your beauty is on my workbook now
http://s15.postimg.org/eta11u6aj/IMG_3594.jpg
'15 S3
'91 200 20v
However...
I will share this with you guys so EVERYONE can know. Do NOT use Cat Billet steel camshafts with the new revision of the Tommis billet cam gear (without some kind of modification)....:
The front interior nose face of the Cat billet cams is .009 taller (longer) than a factory cam. A Cat cast version of the same 2305 cam is only .003 taller than factory. The old style Tommi's cam pulley will tolerate any of these noses, as will other cam gears of similar design. The old style Tommi's cam pulley will tolerate any of these noses, as will other cam gears of similar design.
Old style Tommis (good clamp between back of gear and front of cam):
New style Tommis on stock cam (mediocre clamp):
New style Tommis on Cat Billet Camshaft (no step to apply clamp to the back of the gear relying on only the key):
Hopefully back up and running ASAP.'15 S3
'91 200 20v
