94 S2 Coupe "the classic green pearl"
Those wheels are
With the gearbox oil leak and that 3 bolt sleeve for the release bearing - If you drill a small hole at the base of the sleeves neck at about 6 o' clock it should allow any oil to run straight down. Of course a new seal is unlikely to leak again for sometime but it could save clutch hassle between noticing a leak and rectifying it.Comment
Thanks, they are Zito WP789 in 9x18
That is not a bad idea, something i will do if the gearbox have to go out againThose wheels are
But so far so good, think its safe to say that i saved this clutch.Nur quattro
1994 S2 CoupeComment
Nur quattro
