7A to AAN conversion problem
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Hi,
    One of my mates is doing coupe 20v (7a) conversion to AAN. Engine is fitted, however when he fits his ex-7a gearbox - it is not possible to turn the engine. He is using 10vt flywheel, and clutch which fitted perfectly to my 016 gearbox.
    I know many ppl here have done 3b/aby/aan conversions to the 20v quattro coupes. Is there any issue with gearbox.
    What can possible be the cause of such "stuck" ?
    Sau
  • AnLe
    • Dec 2003
    • 291
    flywheel must be 20v also
    012 gearbox (7a, 3b) has a short mainshaft
    016 gearbox (urq, 20020v, many 10v turbos) has long main shaft
    01e gearbox (aan, aby, 6spd) doublemass can be changed to single mass if s2-3b flywheel and clutch are used.
    • ~Delta
      • Apr 2005
      • 797
      Possible the output shaft of the 7A and the spigot bearing / 10V turbo clutch assembly are not compatible, or the flywheel is hard against the gearbox once the bolts are tightened...
      Get your mate to loosen the bellhousing bolts and see if the engine can be turned then.
      Never show a fool a half built house.
      Never underestimate the power of stupid people in large groups.
      Life is like a **** sandwich
      The more bread you have, the less **** you eat
      • porkkis
        • 1994
        Use the AAN flywheel and clutch and it will work just fine!
        7A cars have a 01A gearbox and its different to 016.
        • AnLe
          • Dec 2003
          • 291
          an just to make clear, depending sources 012 or 01a gearbox family names are used, they are same.
          • Hidshadows
            • Apr 2004
            • 30
            For my AAN into 7A i used a 7A clutch/pressure plate and a fidanza 7a flywheel.
            http://www.jegs.com/cgi-bin/ncommerc...41&prmenbr=361
            $265 US dollars for the flywheel not bad if you ask me. (There is a 1 month wait time though, not a highly bought item here in the us.
            • ThatGUY
              • Sep 2004
              • 794
              Can a 7A flywheel and clutch be matted to a 6spd gearbox? Or would an AAN flywheel be needed?
              //-\\ ((_)) //)) //
              • WabTheKing
                • May 2004
                • 2567
                think i may have a 7a fly wheel lying around somewhere
