building a sportquattro
  • Jeffer
    • 2057
    While browsing through my photoalbum, I came across this picture. I took it myself underneath an original Sport Quattro. It looks like it uses substantial spacers between the subframe.
    RS2 Black - stock 315 HP
    RS2 RS blau - stock 315 HP
    Sport Quattro - 1005 HP
    High Octane website
    • Jeffer
      • 2057
      Originally posted by Puglife
      Lengths is dependant on ride height you want but i'd advise 400-500lb fronts and slightly softer rear springs as a good firm setup... i cant see the SPQ weighing that much tbh and that should be plenty for stiff ride. If you wanted softer then 350 front and 300 rear may be another good basepoint.
      measuring stock Quattro shocks i've gone for 9" 300lb front and 9" 275lb rears on my Coupe Quattro Rally replica...
      Thats interesting info Jay. I like to have it quite low. Not as low as the Dialynx SQ, but not far of that :mischeif:. And as stiff, within reason
      What length size you think that is?
      Later i'll remove the rear spring and will position the car on the lift with the right ride height. That will give me a ball park on the spring length.
      High Octane website
      • GT500
        • Jun 2006
        • 2181
        That will be for a forest/gravel car. Lift the car on the springs for the extra ground clearence and you would want to get the wishbone level again, subframe down would get that done.
        Don't forget its an old way of doing suspension. Has its limitations.
        I recon you won't be running yours at "range rover" heights!
        Keep up the fantastic work! You must be able to see the light at the end of the tunnel?!!
        Rob..
        87 UR 20v ABY
        97 S6 Avant
        • Jeffer
          • 2057
          it looked like original stuff. That car had quite a range rover like ride height So that will be correct. It's indeed a big relief to see the end. Well end it isn't but a major milestone in getting this thing on the road!
          High Octane website
          • Puglife
            • Jun 2006
            • 731
            well, this is just my own personal view and i'm sure others will vary, but i'd say for a good low firm setup you'd want 400-500lb springs and possibly 7-8" springs with a helper spring to avoid any slack on wheel lift...
            Jay - pug_life85@hotmail.com
            1986 Audi UR quattro - WORK IN PROGRESS
            1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
            • quattro84
              • Mar 2006
              • 947
              +1
              Based on feedback from a friend that does the setup for trackday cars that run with a similar overall weight & distribution.
              Static setup with springs is not that complicated in comparance to dynamic load changes with dampers & ARB's.
              @ Jeffer if you bring your springs to me i can measure spring stiffness for you.
              • G60Rallye
                • Dec 2006
                • 1321
                From speaking to various people the 4-500lb range seems about the mark for a firm track set up. The road going sport would need long springs seeing as they only had 15" wheels!
                On another note, how amazing does the old Dialynx sport look!
                • Jeffer
                  • 2057
                  I was planning on measureing the springs today, but it didn't work out. I've got the calculation here aswell Dolf. Will try to squeeze the measuring in tommorrow. Cheers
                  High Octane website
                    A good ballpark to aim for is for the spring/shock to be compressed 1/3 of its travel by the weight of the car.
                    • volcano rs
                      • Jun 2005
                      • 2265
                      that had turrets cut and raised so the spring sits further up . you still have good travel on springs but it also allowes you to lower it without it bottoming out.
                      • Jeffer
                        • 2057
                        ok here are the figures:
                        Front is 151 lbs-inch
                        Rear is 143 lbs-inch
                        The length of the spring is approx 14,5 inch
                        There are are couple of options.
                        1. Cut are few coils, 2 will bring it to 205 lbs. This will lower it approx 7 cm.
                        2. Buy the proper ones.
                        Option 2 sounds best in this case. Dont it?
                        High Octane website
                        • s2driveruk
                          • 12696
                          truely inspirational work and the pictures are fantastic Jeffer. I really cannot wait to see the finished article...lets hope it makes a trip to the UK
                          David
                          1992 3b S2 Coupe
                          • ralleyquattro
                            • Oct 2007
                            • 536
                            • Home: Poland Current: Canada
                            #448
                            Yep, that a road car. Only the front subframe and tranny monunt get these spacers (rear none). Part numbers are 859 199 359 for subframe and 859 199 359A for mounts.
                            Here is couple of pics of the back side of the subframe including the tranny mounts.
                            BTW you have to live under that car to notice all the small details... lucky for me I have filled my camera with pics of couple of cars in my lifetime..
                            BTW rally cars used alloy subframe mounts that had the spacer incorporated into the mount and height depended on the height of the suspension/type of event.
                            Obvioulsy rally cars did not have tranny/diff mounts on the subframe.
                            Martin
                            www.quattro.ca
                            B2: 82 Urq into Sport quattro, 82 4000 2-door, 83 80q 2 Door, 83 Ur-q CDN, 85 Ur-q Euro with 3B, 86 4kq, 59,000km
                            B3/B4: 91 CQ, 93 90q 2.5TDI, 94 80q avant 2.5tdi, 94 S2 Avant
                            • hemihead
                              • Sep 2007
                              • 14
                              • Country: New Zealand
                              #449
                              i've been following this thread closely, i'm doing a lwb build in new zealand so alot of the stuff you've done has been a great help to me. One thing i'd love to know is what are you doing to increase your track enough to fill out the guards without screwing up your geometry? i need to gain 60-70mm a side and from the reseach i've done low offset wheels and spacers give you all sorts of problems. btw i'm pretty sure the spacers under the back of the subframe would be part of the many things they did to restore the geometry when they added track width to the sportquattro. looking awesome anyway keep up the good work!
                              • maartenmoerman
                                • Apr 2009
                                • 68
                                the trackwidth ie distance between 2 front hubs is as far as i know the same on:
                                - cq (typ85)
                                - urq
                                - sq
                                cq has et42 or something on a 6j wheel
                                urq has et24 on a 8j wheel
                                sq has et12 on a 9j wheel
                                they did get away with it.
