building a sportquattro
  • saltinot
    • May 2004
    • 1946
    #571
    Originally posted by Jeffer
    It's alive again!
    Good to hear that Jeffery. Glad you got it sorted.
    • Jeffer
      • 2057
      thanks guys.
      Just drove it for real the first time to the gas station. How EXCITING can that be
      Did hear some alarming noises in the car. The exhaust touches the subframe, this is an easy fix with another hanger. And the right front strut cloinks about. Need to investigate that....
      RS2 Black - stock 315 HP
      RS2 RS blau - stock 315 HP
      Sport Quattro - 1005 HP
      High Octane website
      • G60Rallye
        • Dec 2006
        • 1321
        Never mind about those little bits and pieces that need fixing, its on the road and working thats all that matters for now!
        • JP
          • 1858
          Drain back into the crankcase is a common problem on dry sump setups that sit around for a couple of days. You can easily hydrolock an engine sitting for a week.
          Personally I would always fit a dry break coupling of sorts to isolate the tank to the pump when parked up for any length of time.
          Other than that good to hear your running again.
          UrS6 Stroker + HTA3586 =
          • terrybullwon
            • Mar 2006
            • 8782
            I am sure i read some where on weavers web site if you leave the engine un run you can cycle the pump with the belt of and a gun or drill to clear it.
            Chef
            • caterpillar
              • 2480
              #576
              really nice work !!!!!
              really nice work ,jeffer... who made the flywheel.?? its some porn :mischeif:
              looots of work and many hours thinkin...
              • Audi Parts Guru
                • 1317
                #577
                Jeffer, I hope you will bring this fantastic car of yours to England sometime soon
                • JP
                  • 1858
                  Yes you could I just don't like the idea of oil pushing up against the rings of the pistons lower down the bore. Just incase any seeps past into the combustion chamber.
                  • geryS2
                    • May 2006
                    • 814
                    • Home: Belgium Current: Portugal
                    #579
                    thanks guys.
                    Hope we can see it in real too this summer somewhere in europe ,
                    awesome job, congrats !!
                    S2 's and oldtimers
                    • URQguy
                      • Sep 2008
                      • 245
                      The car looks nice buddy. Good work!
                      1981 URQuattro with the TIAL GT35r.
                      2007 Infinity g35
                      • Jeffer
                        • 2057
                        Flywheel is made by Repo. Fine bit of kit indeed.
                        The first outing is planned to Bittburg on the 14th of may. 1/4 miles on the airfield of Bittburg.
                        I will certainly take it to the uk. Maybe even this year
                        High Octane website
                        • madpugger
                          • Sep 2007
                          • 1901
                          Fancy coming to Le Mans or Nurburgring 700 with it?
                          Awesome project!
                          Le Mans 2012
                          Nurburgring 700
                          1995 S2 Avant
                            Nah he's coming to the MRC day! :mischeif:
                            • madpugger
                              • Sep 2007
                              • 1901
                              Its a pity that MRC day isnt a day or too earlier or I would have come on the way to Le Mans
                              Le Mans 2012
                              Nurburgring 700
                              1995 S2 Avant
                              • G60Rallye
                                • Dec 2006
                                • 1321
                                There has been some talk of competing at ten of the best at the end of July!
                                As for the dry sump system surely the easiest way to sort any drain back would be to take the return line off the pump and zip tie it up in the air?
