Hi guys
After got all the parts togueter will post our next project
ENgine Donor: 1991 2.3l Audi coupe with 90K miles
Head Work: Done by Jose Rodger (www.vwportingtuning.com)
ported, polished, angle job, 1mm bigger SS valves (Intake/Exhaust), titanium retainers, Solid lifters, 7A intake/Exhaust cams, machined to fit water manifold
Short Block:Carrillo Rods, 83mm Wiseco (8.5:1) forged pistons, Stock cranck, Rs2 head gaskets and rod bearings
Drivetrain: lightned 7A flywheel, Stage 4 Specs clutch, S4 6 speed tranny (2001 b5), 4000K driveshaft, V8 rear diff,
Fuel/Ignition system: 90LBS Bosch High Impendance injectors, 2 WAlbro Fuel pump, DTA Pro 8 Stand Alone (www.tpgproducts.com / www.dtafast.com[/url])
Suspenstion:KW full adjustable coilovers
Brakes: front - 993TT big reds in front w/ S8 rotors and custom rats/adpters Rear - 996 4 pistons claipers w/ new bettle front rotors custom rats and calipers
Force induction: Audspeed custom tubular headers with 44mm Tial wg and MTM intake manifold ported and polished to match to the head work
Turbo: custom made GT35/70R. This is an Gt35/40R garrett unit that has been upgrade with T70 compressor wheel, machined the compressor housing. All done by INNOVATIVE turbos in California. the turbo should make 750Whp
Wheels tires:AZEV wheels 17X9 F with 234/40/17 tires and 17X10 R with 265/35/17 michellin tires
Please any advice that i might forget in this project will be more than WELCOME
