engine
My drag car project
Real carbon parts for S2 and RS2. Check Carbondesign on facebook -
caaarAttached Files--------------------------------------------------------
Real carbon parts for S2 and RS2. Check Carbondesign on facebookComment
its awesome
i had 1 year ago the same car as you,but with the original 2.2e 136hp engine
what gearbox did you mount??
and you have different exhaust ,one for the wastegate and other different for the turbo....
LWB Audi Sport Quattro projectComment
i have 6 speed aby gearbox, 70mm exhaust with separeted wg pipe.
today i used the car. eat some sti.
I
BELIEVE YOU
and i think, the front subframe is from the aby too surely with its rear group too.not hibrid with the "3b" rear trasmissions...
and you run with the originals 15" rims??
yes, the front subframe is from adu, baut the rear is stock cq.
i go with 17 inch yokohama slicks.
the final setup:
cq na engine, modified valve pockets in pistons
3b head, with stock cams
rs2 em
aan modified im
k26/27 turbo with #6 hotside
70mm exhaust system with separeted wg pipe
aby 6 speed trany
all bushes changed to hard like stone.
suspensions, springs.
race fuel tank
motorsport fuelpump
440 injectors with 4 bar fuel pressure
whistlerracing standalone ecu
350kpa mapsensor
weight:1050kg (race ready)
370hp on 1.8 bar
very fun to drive
in action:Attached Files--------------------------------------------------------
one moreAttached Files--------------------------------------------------------
we had a good race today. i finish soon. thanks for my new tires.--------------------------------------------------------
short update. we are working to the 2009 seasson.
i have roll cage in the car, new suspension for gravel and 2 more torsens. (front and rear)
i have to work inside and outside the car. i want to make it a good looking racecar.--------------------------------------------------------
Nice. And can I ask you, why your drag racing car project has rally roll cage, two seats and gravel tires?
Preparing for real
with jumps and turns?
Sau200 20vt 88' 3b, human carrier
CQ typ85 with AAN inside, see project blog at http://kwlw.blogspot.comComment
i finished my 1/4mile carrier, when i realized how much money i need, if i want to be serious. this kind of fun is much cheaper and makes a lot of smile on my face.
the other thing, i hate to change engines and heavy trannys.
on rally, is much more depends on the driver, not all about the horsepower and the rest of the car.--------------------------------------------------------
1050kg ?yes, the front subframe is from adu, baut the rear is stock cq.
the final setup:
rs2 em
aan modified im
aby 6 speed trany
race fuel tank
motorsport fuelpump
350kpa mapsensor
370hp on 1.8 bar
very fun to drive
all the shell is fiber glass ?
