Audi 80 B4 2,6 avant quattro projekt
  • Audi 80 B4 2,6 avant quattro projekt
    Hey. Its been a couple of years.
    I gat my Audi 80 avant quattro back for the mechanic, where it has been strandet for 5 years " long story of broken promises "
    Bought a new engine 2,6 ABC on ebay.de The old one lost compression on cylender 2 and 6 and blow all of the wather out of the expasion tank.
    With the help of my neighbor. Him and i put the new engine in and gat it running again.
    So i am tackling the rust problems in the bonnet and doors.
    Fix the wiring in the boot
    Rust in the hood
    New Wheel housing liner
    Still ned to fix the doors bought 4 new, Going to use the winter to changes them. But first i need to get the painted.
    Need help to find thes item i need. thougt the still could be bougt new. Its for S2 side skirts.
    8D0 854 955 B for ring
    8A0 854 953 for cover
    to fix the bottom of the skirt to the car.
    This gallery has 11 photos.
    You can use the B5 Avant ring which is still available from your Audi dealer and the cover is also available. Not such a good fit but with some minor adjustments you can get them to work.
      Sideskirts holds down to the car without attaching bottom part just fine. Fixing covers will break and fall out at some point anyway. I had modified B5 rings and covers, most of them were gone after first winter and two of my friends with B5s said the same.
        Someone needs to three d print a simple push fit plug with a drain hole. If you don't have anything the holes will fill up with mud and trap water, causing rust.
          I just used rubber (plastic?) plugs that comes there from factory on non-S cars.
            Shame you didn't replace the old V6 with something more fun
              Though about that, when the misses blow up the old engine. Looked around for a 2,3 Audi 90 20V.
              But the projekt strandet for 5 years so, when i to over the projekt again it was alot easy to just put in a 2,6
                It's olnly a summer car, it Will only run from 1 of april to 1 of october about. No snow any more.
                I Will Go to the Audi dealer monday a se What i Can order.
                  Spend all Morning under it, trying to fix the aircondition pips again, only to finde out i bought the wrong dryier, the thread on the out going pipe dosen'T fit.
                    This gallery has 3 photos.
                      There's no shame in the V6's, they have typical 2-valve low-end grunt, respond well to traditional hot-rodding and are cheap. What's not to love?
                        What did you use insted of the oem retaining cip to hold down the s2 skirt.
                        This gallery has 1 photos.
                          They not bad engines .I did have Coupe with 2.6 V6 .once its rolling is not bad but let's be honest on pull away they very lazy .
                            No sprint, but that is ok. It's the Sound and feel i love.
                            • #15
                              Plastic inserts (4A0 853 379 E) were available new at the dealership, retaining clips (8A0 853 582) came with the skirts when I bought them but you can cut them out from sheet of metal.
