Audi 80 B4 2,6 avant quattro projekt
  • kokken
    • 62
    • Country: Denmark
    Hey. Its been a couple of years.
    I gat my Audi 80 avant quattro back for the mechanic, where it has been strandet for 5 years " long story of broken promises "
    Bought a new engine 2,6 ABC on ebay.de The old one lost compression on cylender 2 and 6 and blow all of the wather out of the expasion tank.
    With the help of my neighbor. Him and i put the new engine in and gat it running again.
    So i am tackling the rust problems in the bonnet and doors.
    Fix the wiring in the boot
    Rust in the hood
    New Wheel housing liner
    Still ned to fix the doors bought 4 new, Going to use the winter to changes them. But first i need to get the painted.
    Need help to find thes item i need. thougt the still could be bougt new. Its for S2 side skirts.
    8D0 854 955 B for ring
    8A0 854 953 for cover
    to fix the bottom of the skirt to the car.
    This gallery has 11 photos.
    • Dec 2017
    • 5987
    You can use the B5 Avant ring which is still available from your Audi dealer and the cover is also available. Not such a good fit but with some minor adjustments you can get them to work.
    • mdz
      • Jun 2012
      • 775
      • Country: Latvia
      Sideskirts holds down to the car without attaching bottom part just fine. Fixing covers will break and fall out at some point anyway. I had modified B5 rings and covers, most of them were gone after first winter and two of my friends with B5s said the same.
        • Dec 2017
        • 5987
        Someone needs to three d print a simple push fit plug with a drain hole. If you don't have anything the holes will fill up with mud and trap water, causing rust.
        • mdz
          • Jun 2012
          • 775
          • Country: Latvia
          I just used rubber (plastic?) plugs that comes there from factory on non-S cars.
          • piotr
            • Jul 2012
            • 1470
            • Home: Poland Current: England
            Shame you didn't replace the old V6 with something more fun
            • kokken
              • 62
              • Country: Denmark
              Though about that, when the misses blow up the old engine. Looked around for a 2,3 Audi 90 20V.
              But the projekt strandet for 5 years so, when i to over the projekt again it was alot easy to just put in a 2,6
              • kokken
                • 62
                • Country: Denmark
                It's olnly a summer car, it Will only run from 1 of april to 1 of october about. No snow any more.
                I Will Go to the Audi dealer monday a se What i Can order.
                • kokken
                  • 62
                  • Country: Denmark
                  Spend all Morning under it, trying to fix the aircondition pips again, only to finde out i bought the wrong dryier, the thread on the out going pipe dosen'T fit.
                  • kokken
                    • 62
                    • Country: Denmark
                    This gallery has 3 photos.
                    • Lago Blue
                      • Jul 2009
                      • 843
                      There's no shame in the V6's, they have typical 2-valve low-end grunt, respond well to traditional hot-rodding and are cheap. What's not to love?
                      • kokken
                        • 62
                        • Country: Denmark
                        What did you use insted of the oem retaining cip to hold down the s2 skirt.
                        This gallery has 1 photos.
                        • piotr
                          • Jul 2012
                          • 1470
                          They not bad engines .I did have Coupe with 2.6 V6 .once its rolling is not bad but let's be honest on pull away they very lazy .
                          • kokken
                            • 62
                            • Country: Denmark
                            No sprint, but that is ok. It's the Sound and feel i love.
                            • mdz
                              • Jun 2012
                              • 775
                              • Country: Latvia
                              Plastic inserts (4A0 853 379 E) were available new at the dealership, retaining clips (8A0 853 582) came with the skirts when I bought them but you can cut them out from sheet of metal.
