Audi URS4 Big Turbo
  • KMR-Racing
    • Dec 2018
    • 13
    • Country: South Africa
    Audi URS4 Big Turbo
    Hi all,
    Been browsing in the background for some time. I'm from beautiful Cape Town, South Africa. I bought my URS4 about 2 years ago. Car was in Johannesburg and had a fried ECU. Had it picked up from local mechanic where the previous owner was. He installed an standalone ecu, Perfect Power XMS5 and converted coil setup to Audi R8 packs. Few other jobs was needed to get engine started and running. Engine was smoking and had a faint knock. So all work was stopped. Some time passed and I decided to ship the S4 home this week. It arrived yesterday.
    The plan of action:
    Strip interior and clean it all up. Its super filthy and needs allot of work.
    Remove engine and gearbox, full forge rebuild on motor with GT35 spec turbo, will be running E85 (not used as a daily)
    Gearbox also full rebuild with as many uprated parts as possible.
    I would like to document it all as much as I can, so I will be most likely create a Youtube page vids videos of the work and progress. In all aspects I want to do most of it myself with assistance from my dad.
    From what I know its a 92/93 model, 6 speed manual with UFO brakes.
    This gallery has 4 photos.
  • KMR-Racing
    • Dec 2018
    • 13
    Hi guys, quick question. I'm looking at purchasing a set of Bosch EV14 1000cc injectors. Will this be direct fit on stock fuel rail?
    • M_GORDON
      • Oct 2008
      • 1295
      • Home: Isle of Man Current: Vatican City State
      Hi, my setup is more softly and I don't know about those things.
      But... be thinking on injectors when don't be openend the engine...
      Firstly look at all "big things" and later... later's things.
      photobucket SUCKS
      • K Simmonds
        • Dec 2007
        • 7627
        What turbo is currently installed? Looks like some of KKK hybrid, though hard to tell from the one photo.
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
        • KMR-Racing
          • Dec 2018
          • 13
          Well I'm changing the whole setup. So fueling needs to be done. I just want to make sure I get the correct injectors.
          • KMR-Racing
            • Dec 2018
            • 13
            As far as I know its OEM stock turbo.
            • Thuppu
              • 4115
              Keep us posted with updates. This kind of project can easily go out of your hands very fast and you loose control of it.. haha, how I know..
              Anyway. Interesting that it has UFO brakes, so it's basically an euro model.
              • KMR-Racing
                • Dec 2018
                • 13
                Hahahaha, Ive seen your threads.... I will try not to go too crazy! Removing turbo this week. GT35 has already been lined up...….
                • KMR-Racing
                  • Dec 2018
                  • 13
                  Ive got a small issue. Car starts and run fine, however when I switch the car off via the key in ignition it doesn't switch of.... Just keep running like normal. I need to stall the engine for it to switch off.
                  Anyone else had similar issue?
                  • Bowie69
                    • Nov 2013
                    • 2675
                    That can happen when the alternator back feeds, a diode in the warning lamp can solve this.
                    You tuner/installer should have caught this.
                    • KMR-Racing
                      • Dec 2018
                      • 13
                      Thanks Bowie, how do you mean the alternator back feeds?
                      • M_GORDON
                        • Oct 2008
                        • 1295
                        The slim 3rd wire
                        photobucket SUCKS
                        • KMR-Racing
                          • Dec 2018
                          • 13
                          So bad news, tested compression on engine this weekend. Compression was way low. Added bit of oil and comp jumped up by large margin. Rings are screwed. So will be pulling motor sooner than later.
                          Also looking at purchasing Audi 80 Coupe body (V6). Transplanting everything over into that body. I prefer the Coupe over the URS4...…
                          • KMR-Racing
                            • Dec 2018
                            • 13
                            So small update. Motor pulled this weekend. Time to strip and get some parts:
                            This gallery has 5 photos.
