I would rather make a new engine harness from scratch. Sometimes is much easier than modifying the stock engine harness. I am going with new custom wiring as well. In an old stock harness, there could be some potential failure of wire/pin/etc and it's a pita to find it.
struikie - Audi 80 B4 quattro project
Originally posted by Tom_ View PostI would rather make a new engine harness from scratch. Sometimes is much easier than modifying the stock engine harness. I am going with new custom wiring as well. In an old stock harness, there could be some potential failure of wire/pin/etc and it's a pita to find it.
JW| project | 1993 Audi 80 VR6 turbo quattro |
| daily | 2006 BMW E91 335d | 385bhp 735Nm |
Picked the seats up today.
They were being sold by the owner of https://www.oldtimer-textiles.de/ . He bought them
to put in his cabriolet but never came around to doing that.
When we arrived we first had to have a coffee, a cookie and a chat. After that we (I was with my brother)
got a tour of the warehouse. There was a huge stock of car industry textile and leather, including all Audi fabrics.
He also showed us a lot of car seat foam inserts! If he doesn't have it he can make it. This might be a good alternative
for fabrics to Audi Tradition.
Then we got to the seats and they were in really nice used condition, so I decided to take them home.
The armrest is toast, already busy sourcing another one. The sides of the driver seat might need some
new fabric in the future.
After we loaded up the car we even got some warm Turkish pizza for the drive home!
When we got home I texted him we liked the pizza's and he replied that if we were hungry
again we were welcome to stop by
It's fun to go somewhere and meet good people this way!
Originally posted by struikie View PostNice!
I widened them by 8mm because the S-type disc is 15mm and the S4 disc is 22mm.
JW
Originally posted by mr1337 View Post
Hello, your progress with the car is really amazing. I have a question for small brembo handbrake calipers from Jaguar. I have the same ones. Do you have more photos how much mm you cut the pins? I know so the 4.2 S-Type R Jaguar have rear break discs, which are 20mm, you widened your calipers with 8mm which makes 28mm brembo discs. But R8 Genuine calipers are for 28/30mm discs. If I widen it by 10mm, the caliper will be for a 28-30mm disc and i don't have to trim the pins for the Audi R8. Sry for my bad English..
The 22mm S4 discs have a lot of room in the caliper with new pads installed (including the extra 8mm).
It looked like they didn't even need to be widened at all. This might be due to the fact that
they are (also) suited for 20mm discs (and not the 15mm I thought) so the 22mm S4 discs would fit the standard caliper.
JW
Last edited by struikie; 12 January 2024, 12:35.| project | 1993 Audi 80 VR6 turbo quattro |
- 1 like
I have no measurements of the pins. I just cut them to the length needed
It looked like they didn't even to need to be widened at all. This might be due to the fact that
JW
Clean seats!
Used Labo Cosmetica Glico fabric cleaner and an extractor. The water in the extractor was like chocolate milk
Didn't expect that!
- 1 like
Nice project!
- 1 like
Got some special pliers for the fixtures inside the seats.
Stock C4 seats are 575mm wide.
Shortened the outside guide to get to the 535mm B4 width.
Now needs to be welded back together. Luckily I have a friend that has a company
that makes/ builds aluminum parts for boats.
Swapped the front feet between the left and right seat to have the offset go the
other side. Otherwise the feet would be way off.
JWLast edited by struikie; 10 February 2024, 14:45.| project | 1993 Audi 80 VR6 turbo quattro |
- 1 like
Modified the drivers seat harness to remove the memory module.
Now both the seat have the same style harness. Keeping it simple.
Temporary taped up to test functionality.
Soldered, shrink wrapped the connections and cloth taped.
