My 3B Coupe Project
This topic is closed.
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    #331
    Bo are the 2 turbosmarts actually needed? What amount of hp are you going to be runnning?
    • s2_bo
      • Oct 2005
      • 6067
      #332
      You can have a drive next time we meet up Stu.
      It clears the rear driveshaft fine, no knocking yet. They did flatten the underside of the pipe slightly though to prevent from knocking.
      No the tww turbosmart valves are not needed, i just fitted them both because i had them going spare.
      Ill be running about 2.0bar boost.
      91 S2 coupé - RIP
      98 S8 - Luxury barge
      • s2_bo
        • Oct 2005
        • 6067
        #333
        Fitted new spacers yesterday, the new tyres were rubbing on the track rod ends and that was with 5mm spacers.
        This is what the DV's look like now:
        Also braced up the pressure mounted MAF so it doesn't slip off the hose under boost.
        91 S2 coupé - RIP
        • sal_s2
          • 1288
          Almost there Bo! Why have you fitted the maf on the pressure side?
            Originally posted by s2_bo
            Turbo to IC pipe is now done and fitted.
            Looks like this:
            How much did that pipe cost to make Bo?
            • s2_bo
              • Oct 2005
              • 6067
              #336
              Well, i had to have it changed about 3 times because i was lazy and didn't measure anything properly. It ended up costing about ÂŁ30 inc the steel but could have been more like ÂŁ15 if i had done it right the first time round..
              91 S2 coupé - RIP
                Do you have the dimensions for it? Be useful for me if I ever go that route.
                • AurĂ©lien
                  • 48
                  • Country: France
                  #338
                  Why use 2 dv ?
                  • s2_bo
                    • Oct 2005
                    • 6067
                    #339
                    Ill take some measurements next time it comes off Jamo.
                    Im using two DVs because i had a couple left kicking around and thought 1 might not be enough. Better safe then sorry as they say.
                    Maf has gone on the pressure side for better throttle response, in hindsight however it was not worth it as the pipework and getting it fitted in was a PITA!
                    91 S2 coupé - RIP
                    • Acidburn
                      • 13459
                      Top work bo, once its mapped can you post up some clips.
                      You got any decent pictures of the car and how it looks now?
                      • Bram
                        • Aug 2006
                        • 2582
                        Do you feel any difference in driving now with the MAF on the other side of the IC?
                        • s2_bo
                          • Oct 2005
                          • 6067
                          #342
                          Its not plugged in yet, I woant run it like that till tomorrow when it gets remapped.
                          91 S2 coupé - RIP
                          • 4WheelDrifter
                            • Oct 2004
                            • 5773
                            • Country: Devon
                            #343
                            SS
                            • Ross
                              • Aug 2005
                              • 3399
                              So does this mean there's news and its good?
                              • merlin's S4
                                • Jan 2005
                                • 1539
                                Eagerly waiting in anticipation...
