The big experiment - amateur 3B shenanigans
  • Nj
    • Jan 2007
    • 3420
    • Home: Scotland Current: Finland
    #331
    Originally posted by Nuvo
    Another one brought back to life. Well worth the effort and well done too!
    You must be Mr. Chuffed if I'm not mistaken.
    cheers Rob
    Mr Smug for now. More so when it's all shiny and looking good (and road legal). given the price I paid to start with for the broken car it hasn't worked out exactly cheap (even just thinking about the tools i've bought) but then I was uneducated then. So when I buy my next broken s car i'll know better what to pay for it and what's waiting for me. :mischeif:
    1990 CQ20v
    • Nj
      • Jan 2007
      • 3420
      #332
      buggr. main beams are working but side lights aren't. I must have missed something on the loom. hmmm.
      1990 CQ20v
      • Knight Rider S4
        • 3541
        are they connected?
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • Knight Rider S4
          • 3541
          fuses and check relays
          93 S2 Avant Parting
          91 URQ RR
          02 A4 tdi Avant
          • Nj
            • Jan 2007
            • 3420
            #335
            def connected cos sure the unit is all in one mate. had assumed that the sidelights and main beams would be on the same fuse and relay. any tried and tested way of testing a relay I should know of?
            cheers
            1990 CQ20v
            • Nuvo
              • Nov 2003
              • 3825
              #336
              Noel, I'm pretty sure the headlights don't have a relay believe it or not (just a bulb monitoring relay as used by autocheck).
              • Nj
                • Jan 2007
                • 3420
                #337
                that will be one less thing to check then.
                cheers rob
                1990 CQ20v
                • Knight Rider S4
                  • 3541
                  Well if you dont have side lights first thing to check would be if there is power going to the lights and work your way back ..maybe those two plugs???
                  Do you have ETKA?
                  93 S2 Avant Parting
                  91 URQ RR
                  02 A4 tdi Avant
                  • Nj
                    • Jan 2007
                    • 3420
                    #339
                    aye I think that'll be the plan. i'll be investigating those 2 random plugs on the passenger side. Also there's a single wire on the driver's side that's been cut off. it has a thin green connector in line and then the end's missing. I know it was like that but wtf did I do with the old loom that I labeled and cut off the old shell? damn. i'll figure it out anyway. no biggie.
                    1990 CQ20v
                    • Nj
                      • Jan 2007
                      • 3420
                      #340
                      here's a doozie for the big brains....
                      When I go to start the car it turns over and splutters a bit. I persist and it starts and turns over for a few seconds but very lamely. I persist more and it will idle but very lamely and eventually it will lift in tone and idle properly. If I try to rev it a bit it chokes and may stall. But persisting will get it running properly. I can leave it like that or take it for a spin (I did take it to halfords at the weekend and propelled myself a strip of dual carriageway like a missle so the engine works ok) and if i turn the engine off for a bit (as I did going into halfords) it starts again no problem. But when I leave it long enough to cool down i'm back to p155ing about to get it started again.
                      Does anybody have a friggin clue what's going on? seems as if the engine will only start if warm. or I could have an issue with fuel getting through?
                      Also the boot was shutting and locking ok until I put the plastic strip in (that goes from the parcel shelf lugs either side round the back and around the lock mech) and the rubber boot seal in. now when I close it, it just thumps like the mech is locked. seems to line up properly and I haven't adjusted the position of teh tailgate. also has me stumped.
                      All answers greatly appreciated.. or some possibly scorned and poked fun at.
                      cheers
                      1990 CQ20v
                      • Acidburn
                        • 13459
                        Boot lids are always a pita and require a bit of effort to shut.
                        Idle - could try cleaning your idle valve, could also be that the car just needs more using or a service?
                        • Nj
                          • Jan 2007
                          • 3420
                          #342
                          you mean i'm a big girl and shut it harder or something needs adjusting?
                          I'll try the idle valve. good thinking. I did change the filters and oil while I moved the engine across. sparks plugs seem ok. just seems very odd that this happens until the car is warmed up and then it's happy.
                          cheers mate
                          1990 CQ20v
                            #343
                            Boot lid shouldn't need to be slammed - smells of bad adjustment.
                            On the cold start issue, I'd suggest its an ECU sensor issue - the ISV wouldn't be doing much until it starts. Check air and coolant temp sensors.
                            Alternatively if its struggling to spark when cold, then it could be a problem with the coil - its a 3B innit ?
                            Paul
                            • Nj
                              • Jan 2007
                              • 3420
                              #344
                              yeah the boot has to be something daft if it shut ok without the seal but won't shut now.
                              the bigger issue is the engine. how would I go about checking the air and coolant sensors besides checking the wiring?
                              coil sounds possible. Yeah it's a 3b by the way. it's firing fine once warmed up though. would the coil be affected by the temp in some way?
                              cheers for the input
                              Noel
                              1990 CQ20v
                                #345
                                and
                                and
                                plus a bunch of other stuff at http://www.s2central.net/motronic_02.html
