My 3B Coupé Project.
Stu did you get clutch from the states or is there a UK rep?
SteveLeave a comment:
Looking damn good Stu!
Anytime you need a bit more motivation, feel free to come spend a day working on my car
I can't wait to get the final update on the thread with the car running!! Although I'm sure it won't be the "final" update but anyway...
It certainly is addictive, the temperature and a bit more light are making it easier, as is having a mini-meet to help out
I've got the bug again
I'll ask about the crank locking tool
It's about time I updated this thread.
Getting the new clutch balanced wasn't as simple as I thought. I took it Bassett Down Balancing with the flywheel, but Philip needed it bolted to a crank to be able to balance it. So I had to wait for someone else to send in a suitable crank for balancing. But we got there in the end.
I feel much more confident now I this clutch once again.
I also got the cylinder head finished off. I cleaned it up and lightly ported it some time ago. Thanks to Bo and his contacts, new valve were guides pressed in and the head was lightly skimmed.
It was great to get the engine back in. Here it is with the ARP head studs and metal head gasket fitted.
I also gave the original brake fluid reservoir a good clean inside and out, as it is another part that is NLA. I just need an assistant now to lend me a foot to bleed the clutch. That's not so easy now with that damn 6 speed linkage, but access is pretty good otherwise ATM.
I got a bit eager and assembled the head without taking any photos. Here it is in the car.
It's not bolted down yet anyway. I've got some OEM headbolts somewhere that I want to get the washers from, as the ARPs look too small. I've also left the cams out for now, so I have a non-interference engine. I'm hoping to collect a lower cam pulley from Volcano RS sometime soon. I also need a tool like DJones's to lock the crank with my balanced front pulley.
Thanks to Ross for letting me work on his car at the weekend, it spurred me on a bit. Although I must say I prefer to fit a short block by hand, as opposed to a full engine with a hoist.
I'm looking forward to BST so I can spend some evenings on my own S2.
Blimey! It's been hard to get any time with the old banger this year. Having to work abroad hasn't helped, but yet another summer failing to appear has hindered progress too.
The engine is out and back in the garage again. The Spec pressure plate has been removed, as I now have the Clutchnet one like I had in the first place. I just need to get to Bassett Down to get the new one balanced.
The rear end is coming together nicely now, and I bought these a few weeks ago...
As much as I think the build quality of KW components suck, the handling/ride quality balance is good on other car's I've driven, so I think they are worth a go. I have plenty of other suspension options in the garage if they turn out to be no good.Leave a comment:
Here's my original AYV rear diff before I took it apart.
And here it is after I cleaned it, stripped it, replaced various seals and other parts.
Now it's on the car and I've got to sort out some sort of hybrid propshaft to link it with the DSY gearbox. I also need to get some new vacuum hose for the diff lock.Leave a comment:
Ha ha. It's got worse than that now. I should set to it with the strimmer to give the weeds a trim.
I had to hacksaw the bearing carrier off. It was quite tricky with the lack of elbow room under the car.Leave a comment:
yeah thats better
really need to get some of that stuff for mine. Did the prop bearing release ok from the mount or did it need a good tw^t with a hammer to break its grip?
It's the part at the top of the oil pick-up pipe that locks the bolts. The P/N is 035 115 259.
Yep. A bit of scrubbing and a few coats of paint later it looked like this:
