Guys,
Some of you will know that I've been considering doing an S2 Sedan conversion. This would essentially involve converting a B4 80 Quattro to 'S2' spec using either an S2 Avant, or an RS2 as a donor car.
The purpose of this thread is to explore how this could be achieved, any potential problems and for me to ask questions as they occur to me.
Current thinking is that the S2 Avant/RS2 share so much in common with the B4 chassis 80Q that it would mostly be a bolt-on job. Suspension, transmission mounting points are apparently the same, and interior should be swappable also.
The most difficult aspect that's come to light so far is that we'd have to re-weld the engine mounting brackets for a 5-cyl, as the 6-cyl mounting points are different (although not sure about the 2 litre 4-cyl 16v variant of the B4 80Q...). Also the loom and ECU would have to be swapped, although apparently this isn't difficult.
If anyone can think of any other points of difficulty, or even a reason why this conversion can't be done, please let me know!
Cheers,
James
Cheers,
James
