The Green Monster Project - Stroker GT30
  • terrybullwon
    • Mar 2006
    • 8782
    Originally posted by Faheemo
    Torque plates cost GBP 40 , getting it to the UK will probably cost more...
    I'm sure you can get a set made up for similar
    For got about this, I made one up in the end
    Thank you any way and good luck
    Chef
    • Faheemo
      • Feb 2005
      • 544
      • Country: South Africa
      #92
      I tried grinding a used head gasket clamped by the torque plates , but this was not suitable as the dremmel kept on jumping and damaging the torque plate.
      Therafter i sent the torque plates and new gasket to the engineers shop to get em bored on a cylinder boring machine, just like how a block is rebored !
      So we finally got the head on - next battle is the wagner IM that needs nipples, isv connections, dipstick holder and machining around the water manifold area.
      also injector fittings.
      Does anyone have an idea if i can buy injector stops that fitt from the underside of the manifold ?
      Also busy installing a new setrab oil cooler.
      S2 Coupe fully built.
      10.9 1/4mile 0-100 in 3.5secs
      Precision 6262 turbo
      The Green Monster
      • Lupo911
        • Apr 2005
        • 312
        please Post a Picture of the Injector Seats, it sounds like you got an 5+ Year Old Version of our Manifold.
        • Faheemo
          • Feb 2005
          • 544
          #94
          here's a picture of the manifold - i bought if from Habib on this forum.
          Please advise Lupo ...
          The Green Monster
          • Lupo911
            • Apr 2005
            • 312
            Ok, its not that old.
            The Injector Seats are done with machining, you dont have to machine inything to it. The Injector will fit rigth into it.
            Grind a little bit where the Water Flange is located, should be done in 10 minutes. If you need some Vacuum Nipples or Throttle Cable holder just send me a Email or so.
            Its not much Work to be done, i do need 30-45 Minutes to make this Manifold fit into your Engine May.
            If you have more Questions Mail or Call me.
            • QuattroFever
              • May 2006
              • 1360
              jkl
              Volcano ABY coupe
              Ant
              • QuattroFever
                • May 2006
                • 1360
                I'm using a dual injector setup with a variable controller.
                Water injection lowered my intake temperatures by 10deg as well, but i don't tune for water injection. The biggest advantage of the water injection is that the intake temps fall quickly after the car is stuck in traffic on hot day or you have a lot of heat soak in the engine bay.
                I decided to weld my own Exhaust manifold ....
                Read a post on Vortex and it looked like a DIY Job...
                not too handy with the argon welding so after a while i had to call a friend to help me out. He's not so good either
                Looks a little better after i ground the excess welding and sent it to the engineers to skim the surfaces.
                I heard stainless turnips are all the rage in South Africa!!
                Volcano ABY coupe
                Ant
                • andy112
                  • Nov 2006
                  • 133
                  • Home: Poland Current: Canada
                  #98
                  nice project
                  • Faheemo
                    • Feb 2005
                    • 544
                    #99
                    Wagner Intake manifold is finally ready.
                    The Green Monster
                    • Faheemo
                      • Feb 2005
                      • 544
                      #100
                      I will paint the inside of "S2R" sign later and polish the face.
                      Just to decide the colour : Black or Blue ?
                      The Green Monster
                      • Faheemo
                        • Feb 2005
                        • 544
                        #101
                        Next is to make the cross memeber and get the intercooler to fit in the bumper, an i dont want any chav comments.
                        The intercooler is a mother sized L 800mm by H 270mm x W 90mm (overall)
                        (the core is by garret: 620mm wide)
                        From S2_bo and other posts, its going to be a mission to get this cooler to fit under the bumper.
                        but i have a trick or 2 up my sleeve.
                        Firstly - In the pictures below i took to butchering the bumper in order to increase the airflow to the intercooler.
                        The Green Monster
                        • Faheemo
                          • Feb 2005
                          • 544
                          #102
                          Here's a side by side of the intercoolers.
                          Ive already modified my old S2 intercooler to fit into my family car a 1.8T Passat.
                          Gotta make some mods on the new cooler to get it to fit ...
                          The Green Monster
                          • Muaazh
                            • Apr 2008
                            • 1
                            lol, finally registered , lekker project, paint the Wagner Intake manifold black
                            • Faheemo
                              • Feb 2005
                              • 544
                              #104
                              The Green Monster has awaken from 9 months of hibernation.
                              Transformed into an S2R ....
                              The Green Monster
                              • A80Avant
                                • 10873
                                • Country: Greece
                                #105
                                niceeee
                                the only thing i didnt like in mine as well,so i changed it was the water lines which have to come above the cyl.head...
                                nice bling bling though!
