My 3B-AAN 400 HP project
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    #211
    This is compressor map.
    Why i bought this one...dont asq me...
    I started another thread to search the right turbo...
    • Pirvu Eugen
      • Apr 2007
      • 1978
      • Country: Romania
      #212
      As i changed my mind regarding the ecu. I started gathering the missing parts.
      Timing sensors and knock sensors will be here shortly.
      I bought this!
      • Pirvu Eugen
        • Apr 2007
        • 1978
        • Country: Romania
        #213
        Took the head out again to weld the hall sender bracket.
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          #214
          after 7 years... engine is running!!!
          Offf!!! The first ecu i tryed was bad and i didint know why fuel pump relay and injectors were running .but not the coils...and the WGFV was clicking like it was receiving signal from nowhere. Lucky i had an spare unopened ecu..and!!!!happy times!!
          • LHD_Kid
            • May 2006
            • 3697
            #215
            finally .....! It's alive.....! It's alive I tell you...!!!!
            • Pirvu Eugen
              • Apr 2007
              • 1978
              • Country: Romania
              #216
              without water...so not too much...
              • Pirvu Eugen
                • Apr 2007
                • 1978
                • Country: Romania
                #217
                question for ecu masters
                Stupid question...but...i noticed that after all the changes made to the engine, is hunting at idle. Don't know if is because lower compression, bigger turbo, lightened internals.
                Or is something i did wrong during assambly ?
                I have no clue about what to check.
                The compression is 155 psi on all cylinders.
                No boost leaks.
                Is pulling ok with stock boost levels, no boost cut.
                Isv cleaned and changed.
                Plugs are NGP bxr7eix gapped at 0.6
                AAN ecu
                Maibe is normal because all these changes...but i am a little paranoid about this.
                Thank you!
                Eugen
                • RichLV
                  • Mar 2015
                  • 872
                  • Country: Latvia
                  #218
                  Is the ECU mapped for the new hardware? If not, then that will probably be the cause.
                  • Pirvu Eugen
                    • Apr 2007
                    • 1978
                    • Country: Romania
                    #219
                    Is not mapped... Is aan ecu standard. Injectors are still aan. For now... Just different turbo, lowered cr by skimming pistons, scat rods... Balanced...
                    Couldint immagine can do this at idle... This is why i am worried..
                    • Thuppu
                      • 4115
                      It also does it more easily with a light flywheel.
                      • Pirvu Eugen
                        • Apr 2007
                        • 1978
                        • Country: Romania
                        #221
                        It has an lightened fly indeed!!
                        Thank you guys!
                        • LHD_Kid
                          • May 2006
                          • 3697
                          #222
                          Thank you guys!
                          It's not much lighter though, is it? I thought was only a minimal difference...
