Projekt k24 Alpinweiss
    My profile pic? This one:-
    Taken heading up to Karussel, there's a sequence of about 5.
    Or this one:-
    Taken at Donington.
      Great story Andy - I respect the approach you've taken with the car - a similar route to that which i'm following, sorting out all the wear and tear items and concentrating on the chassis before chasing power
      Do you think you'll ever polybush it? I know its still a day to day road car, but i wonder whether poly wishbone and subframe bushes might be a better compromise for control that OEM rubber w/bone bushes and alloy s/frame mounts?
      Care to share any info RE: the potential 22mm ARB for the rear :mischeif:
      Alex
        22mm RARB is off a really basic 80, I found it in the family album.
        As the wishbones are fairly new front and rear I'm going to leave them for now but a set of cast wishbones and poly bushes at a later date. Rear subframe was rebuilt 18 months ago so I'm going to leave it for now. 3 of the front subframe bushes are 6 months old but as one needs replacing I quite fancy trying the increased castor ones instead. When things get a little squishier I'll start on the Polybushing.
        AC bolt was one that went into the block, best replace them with shorter bolts.
        • Azman
          • 3205
          Great write up matey, After reading it most def agree that the smaco's and all the vaccum pipes need doing, just had a problem with mine on the overboost, just stuttered a bit, replaced all the vaccum line I could get my hands to easliy for now and bobs your uncle pulls like a train (also done the Mark H Mod on the cooler) and even hits 1.2 bar on full plant down very briefly on the stock map...... Hmmmmmm things to come. You are a man testiment to the love of these cars dude. Keep it up.
          Az
          Dark Grey Avant
          RS2 FARB
          Alloy Subframe Bushes
            I just get attached to cars and then get carried away...
            • Big_kev
              • Dec 2006
              • 159
              Marriage Saver
              Cheers for the write up Andy.
              helped explain to my better half that the obsession of the S2 is not just limited to me
              • Acidburn
                • 13459
                It was the donny one that I was looking at, cool
                  I think I've gone through a front wheel bearing in just over a year. Getting a low rumble/grinding noise when turning right with load on (fast roundabout, spirited B road). Oh well!
                    Got more goodies coming in the form of a set of DS2500s for the front (replacing the ones I fitted in October last year ) The old ones did 10 laps of the 'ring, 2 sessions at Combe and a day at Donington... they were absolutely ripped to shreds by the grooved discs that I have fitted. I got the new ones from Circuit Supplies at the absolutely bargainous price of £96+ Vodka & Tonic. These will be matched up to some plain discs ready for my next track excursion later in the year.
                    I've also completed the catch tank installation except for a boost leak test although the GTech is reading a health 240bhp ATW.
                    The track tyres are getting fitted to the OZs tomorrow (I hope) and the Eagle F1s are going onto the old Dezents (that I'm in the middle of refurbing ). Going to scrub the track rubber in for a week or two.
                    Still to do:-
                    Braided brake hoses
                    Brake fluid
                    Prop centre bearing
                    Passenger wheel bearing
                    Move engine back a bit or fit offset subframe bushes
                    Attach the bumper at the front proper like as it's a mess
                    Get the Milltek DP and sports cat fitted
                    Fit the 7A inlet cam
                    Await some newer vintage ABY NI based homebrew
                    Oh, and give the old girl a bloody good wash and wax!
                    • denniselbows
                      • 740
                      how long did it take circuit Supplies to send you your pads? i have been trying to give them a ring all week to order some myself but haven't had a chance to give them a ring
                      never set your expectations to high that way you are never disapointed
                        Ordered today, if they're less than 2Kg I'll get them tomorrow, more and it'll be Monday. Great price though so worth the wait.
                        • denniselbows
                          • 740
                          yes does look a top price . i saw some place online wanting nearly £200 for some for porsche mono blocks
                            Indeed, my local chap wanted £200 for them but £110 for MIntex CTECH 1144s, I was tempted.
                            Got a bit of a squeak coming from the rear pads under light braking, I suppose that's the price you pay for more aggressive pads
                            • s2driveruk
                              • 12696
                              yeah, i'd steer clear of those M1144's, had them on the standard S2 brakes and they were wooden and ate the discs
                              £96 for Ds2500 is awesome...I'll remember that for mine.
                              1992 3b S2 Coupe
                              • denniselbows
                                • 740
                                just to comfirm the p/n for ds2500 for the monoblocks is frp 3051 h is this correct?
