220v > Rs2
  • OrMar
    • May 2007
    • 132
    • Country: Croatia
    #31
    Modest try to take at least a bit of load from exhaust manifold:
    • OrMar
      • May 2007
      • 132
      • Country: Croatia
      #32
      Lean one
      So, to resume:
      Hardware is as follows:
      - 200 20V with 3b engine, rebuilt
      - RS2 turbo
      - RS2 EM
      - original 3b airbox with additional 80mm hole in the bottom
      - big FMIC
      - standard 220v exhaust, no cats
      - 4 bar fuel pressure regulator
      - RS2 replica injectors from 034
      - RS2 software for 3b
      - motorola 3bar map sensor
      Car is strugling to make boost, mixture goes completely lean (I have AFM on standard o2 sensor) as soon as I press more that half a throtle.
      Car eventually makes 0.8 bar, but I'm afraid to hold WOT for more that 2-3 seconds with such a lean mixture.
      I tried swaping:
      - 2 different fuel pressure regulators
      - 2 different versions of software
      - RS2 fuel pump
      No result.
      Any opinions ? Could it be bad MAP sensor ? Is reads 0.7 on the dash where original map used to read 1 (with engine not running), but I guess it's to different scaling.
      Thank you,
      Mario
      • OrMar
        • May 2007
        • 132
        • Country: Croatia
        #33
        And my self-replies go on ...
        Did a little bit more testing today: mounted fuel pressure gauge, and it seems to be ok: some 3.7 bar at iddle, and raising with boost. But car just refuse to go ... until some 5000 rpm.
        So, until some 5000rpm I have almost no boost (less that 0.5 bar) with air/fuel meter completely on lean side (unfortunately, I don't have wide band). But once after 5000rpm, boost raise to 1.55bar and she rocket herself.
        I am really out of ideas what could that be other than map totally unadjusted to my hardware (7a exhaust cam and big FMIC in particular).
        Opinions, please ?
        Thank you,
        Mario
        • A80Avant
          • 10873
          • Country: Greece
          #34
          i dont understand how you can measure the AFR without a wide band...
          if you are only using a narroband,then if the mixture is going into lamda=1 then that is normal,as the narroband cannot measure rich mixture anyway
          • OrMar
            • May 2007
            • 132
            • Country: Croatia
            #35
            I have one of those air/fuel meters connected to stock lambda sensor. It only have lean/normal/rich scale, but it can give you some perspective what is going on. But even if it's totally inacurate, my "butt-sensor" tells me car isn't going anywhere.
            Mario
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #36
              where did you get the RS2 software for your 3B engine and wich setup inside the chips?? boost??
              • OrMar
                • May 2007
                • 132
                • Country: Croatia
                #37
                I bought software from a guy on german Meckis forum. He said it's been "made by MTM, 360HP/540NM, 1.9 bar overboost and 1.3 at 7.000 rpm", but who knows ... Too bad it's such hard to find 3b software, hope Paul will improve that soon.
                Mario
                • A80Avant
                  • 10873
                  • Country: Greece
                  #38
                  afr will never show you how rich the mixture actually is with the narrow band lamda sensor.YOu cannot judge by that.Get yourself a wideband fitted and do the tests
                  • OrMar
                    • May 2007
                    • 132
                    • Country: Croatia
                    #39
                    I will.
                    However, if this instrument is stuck in lean on wot at anything bellow 5000 rpm, car doesn't make a boost and goes nowhere, it tells me there's something wrong, or ?
                    Mario
                    • Rocco
                      • Aug 2007
                      • 6393
                      • Country: Spain
                      #40
                      Mario
                      take care with your RODS
                      • OrMar
                        • May 2007
                        • 132
                        • Country: Croatia
                        #41
                        I have Aron's items in engine, he said these are good up to 5000HP/12000 NM.
                        Mario
