Non-Stop 3b upgrade
Now is just after the intake filter
But later maybe we are going to map it with speed density.... So maf uselessLeave a comment:
What do you want to blow first?
Turbo
Engine
Clutch
Gearbox
Diff
Driveshafts
I need to mod the downpipe and the screamer to can install the huge turbine outlet
What's best? 3"V-Band or 3" 4 bolt fitment? Because needing to mod,I can use any of both for more or less same priceLeave a comment:
I hope to break some transmission consumables with those stuff... And the 650hp barrier either
The turbo is king size!!
Here gtx3582 .82ar presented with his new teammate "Repo" new T3 tubular manifold
just bought some good items , this will and must be the LAST power upgrade
so in addition with Aquamist HFS3 must break easily the 600hp barrier
GTX3582 .82AR
Bosch 1000cc injectors
3" cutout exhaust valve
i hope that after this i just only need to do maintenance with consumables like oil,coolant,coils,driveshafts,gearboxes and rear diffs
