Had a little more time to polish things up over the last couple of days. I removed the coil packs from their aluminum cover on the kitchen table. My wife was obviously not home at the time.
After a session of being pelted with glass beads the "20V turbo" lettering on the valve cover had lost their machined look so I wrapped some 1200 grit sandpaper around a flat piece of plastic and began to sand the tops of the lettering. After just a few minutes the letters started to look as they did before. See below.
After I sanded the letters I took some alu polish on the end of a pencil eraser to add just a bit more shine.
Polished up the heat shield.
Coil packs reunited with the cover and mounted.
Fuel rail and injectors installed with new o-rings
Once I've finished stripping the donor car and get it off my lift I will be able to pull my car in and get busy removing the old motor.
I sent you a PM.
