Palma RS2 450-500hp
  • aelred
    • Jan 2005
    • 761
    Still no turbo?
    Aelred
    • jade
      • Jan 2005
      • 1811
      • Home: New Zealand Current: Spain
      #32
      Originally posted by aelred
      Still no turbo?
      Turbo arrived this morning, I have fitted the in engine now ! I will post comment's latter
      Regards Wayne
      RS 2 580HP
      • s2_bo
        • Oct 2005
        • 6067
        #33
        Cant wait to see this
        91 S2 coupé - RIP
        98 S8 - Luxury barge
        • A80Avant
          • 10873
          • Country: Greece
          #34
          and photos please!! i would like to see that turbo!!
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            #35
            come on,come on¡¡
            • jade
              • Jan 2005
              • 1811
              #36
              Well I have had a lot of hold ups with shipping, I finally have most bits now
              Photo of the Bad boy in place
              Big cold side compressor 58
              .63ar hotside very small hot side housing, I will need to use a 10mm spacer between turbo & manifold
              RS 2 580HP
              • A80Avant
                • 10873
                • Country: Greece
                #37
                indeed! the .63AR is quite small. Also it seems that the turbine wheel is protruding quite a bit! weird!
                Do you think that the .63AR will be a problem jade(for the EGT's that is)
                Also did you order the cold side with anti surge, or normal 4inch?
                • jade
                  • Jan 2005
                  • 1811
                  #38
                  .63AR is what Justin recommend for early spool
                  Normal 4" cover
                  RS 2 580HP
                  • A80Avant
                    • 10873
                    • Country: Greece
                    #39
                    did you get it with oil and water cooling?
                    fits nicely on the spot by the way!!! tight,but fits!
                    • jade
                      • Jan 2005
                      • 1811
                      #40
                      Some how i received only a oil cooled one, But that will be replaced by comp turbo, Bit of a pain but **** happens. but i get to keep this one !
                      RS 2 580HP
                      • A80Avant
                        • 10873
                        • Country: Greece
                        #41
                        what do you mean?
                        will they send you a second turbo>???
                        • jade
                          • Jan 2005
                          • 1811
                          #42
                          what do you mean?
                          No Just the centre section i will have to use old housing hot & cold
                          RS 2 580HP
                          • A80Avant
                            • 10873
                            • Country: Greece
                            #43
                            oh i see!!
                            that is cool! good support then!
                            cant wait to hear the results!
                            • auditude
                              • 407
                              I heard an interesting thing about non-water cooled turbos. Basically it was that having coolant go through the turbo did little for the turbo, but instead heated up the coolant and rest of the engine by quite a bit unnecessarily. Supposedly this was from Lindsey Racing, an outfit here that does Porsches, particularly 951's. I didn't see anything about that on their website, however. It was an interesting concept, I thought.
                              Kenneth
                              1990 Coupe quattro
                              1991 200q20v x 2
                              1985 4ksq 20vt project
                              1986 Coupe GT 10vt project
                              2006 Honda Ridgeline
                              1998 Honda VFR800FI
                              • A80Avant
                                • 10873
                                • Country: Greece
                                #45
                                it is , indeed,but with a sufficient radiator i wont think that it is a problem.Maybe when sitting in traffic perhaps.But audi must have had something in mind when they used it.
